Question about Frigidaire ATF6000ES Front Load Washer
Affinity front load #ATF6000ES
Help.... my washing machine door is locked. I cannot unlock it. I unplugged it for 30 minutes but it didn't fix it. Is this a bad switch? Thanks much.
    Novelist:
  • 116 Answers
The latch may just be stuck. Try pressing in on the door at or near the latch point and start then pause / cancel a cycle (while still pressing inward).
if that fails, put the washer through a spin/drain only cycle and let it run through( no need to press on the door).
If you are still unable to unlock the door you will have to call for service.
Posted on Jul 28, 2008
How can you tell when the door lock is bad on a 2011 frigidiare affinity front loader washer
Mike,
I understand that you are wanting to know how to tell if the door lock is going bad on your Frigidaire Affinity washer. One way to tell is if the washer is telling you that the door is not shut or locked when it is. Try to reset the appliance for 3 minutes, by either unplugging it or resetting the circuit breaker. If you are still having trouble with the door lock, I would suggest to have a local authorized technician to come look at the lock and fix it if necessary.
-Best Regards-
Jan 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity washer FAFS4272LA0 is cutting on by itself with no lights on, the door locks, then when I turn the knob it says 0:03 draining.
there is a problem with the control board its possibly got wet at some stage or other I would take a hair dryer to it and try to dry it out and then try plugging it in again eric
Dec 27, 2017 | Frigidaire FAFS4272LA Affinity 4.2 cu. ft....
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
I'm getting the blinking locked door light and error code e48
e48 SAYS THAT THE MACHINE DETECTS THAT THE DOOR IS NOT LOCKED.UNPLUG MACHINE FOR 30 MINUTES TO SEE IF IT WILL RESET.iF PROBLEM PERSISTS,YOU MAY NEED A DOOR SWITCH
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
How do I unlock washer door?
Have you tried to unplug the machine, often with errors the machine will lock down and become unresponsive, unplugging for 30 minutes helps to reset them.
Oct 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Affinity Washer: Will only display 56...Pau, Err on any button
This was exactly what was wrong with my washer!!!!!!!!!!!!!!!!!!!! Stupid Easy Fix! I would recommend leaving it unplugged until you are ready to undo the plug for the door lock. This was a perfect solution!!
Feb 27, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
251 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
