Seems something is wrong with the Elevation function. I do a bike ride during lunch at work, starting from the parking lot, about a 10mile look and end at the same point. After I upload the data is shows a resulting elevation delta of about 30ft. This is not a hilly area I am riding in so do not expect much margin for error. I would expect this would be accurate with a foot or so. Anyone heard of seen this problem
-   my unit intermittently powered down so i opened the case to fix
thecontacts. now the timer works great, but the altimeter doesn'twork
and will read 65616 on occasion. how did i damage thealtimeter by
opening the case?
-   swilson313
Sorry to have to break (no pun intended) this to you, but I have had two units do this. Once this problem starts eventually the Elevation field will display and stay at 65616. The problem is with the barometric altimeter and cannot be fixed without sending the unit to Garmin. When you call Garmin technical support, they will have you do all sorts of resets - be patient - eventually they will concede that the unit is busted and give you an RMA. Both times this happened was after the unit got a little roughed up (one time dropped it, the other time was mountain bike tumble) - evidently the altimeter is the least robust part. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Garmin Edge 305 GPS Receiver
My edge 305 doesn't always pick up sallelite. I use it on my bicycle and it fell off adaptor onto...
(More)
My edge 305 doesn't always pick up sallelite. I use it on my bicycle and it fell off adaptor onto pavement. It was working fine until a few days after that. Sometimes when I turn it off and turn it on again it will work, but it's getting worse now.
I will be riding a 340km 24 hr mtb stage race consisting of 6 stages in dec. How do I manage...
(More)
I will be riding a 340km 24 hr mtb stage race consisting of 6 stages in dec. How do I manage charging of my Garmin Edge 305 over what will be some 18hrs of riding with short breaks between stages?
my garmin edge 305 freezes up during the ride on occasion. the distance and elevation numbers just...
(More)
my garmin edge 305 freezes up during the ride on occasion. the distance and elevation numbers just stop changing, while I'm still riding. thanks
