Question about Compaq Computers & Internet
Please help me my hard drive fan is permanantely on
    Problem Solver:
  • 15 Answers
In your previous post about the same question i didnt consider it being a controlled fan, i was thinking more along the same lines of a case fan, plugged into the same p/supply with no sensors
Posted on Jul 28, 2008
    Novelist:
    Scholar:
  • 160 Answers
Fans are controlled by heat sensors - when they reach the threshold temperature, they turn on. The sensor and fan can also be affected by dust.
Turn off the computer, open it up, and vacuum out all the accumulated dust in all openings you can see. Using a can of compressed air (from an office supply store), blow, vacuum, and wipe until you got it all cleaned out.
With dogs and cats in my house I need to do this every month or so.
Also, make sure the computer is in a spot with plenty of airflow around it. Locked up in a cabinet or in a corner on the floor does not allow good air circulation. Consider putting it on a box to raise it up about a foot off the ground if you can.
Finally, you may want to install SpeedFan It's free, and a great monitoring program for all devices. There are many tips on the site for dealing with temperature issues.
Speed fan will also tell you the performance status of your drive, including an estimate of when a failure may be coming up. It's possible that if your drive is on the verge of failure, it could be generating heat. And it's possible that an overheated computer could shorten the life of all the components, including the drives or CPU.
By the way, the only hard drives that have fans are either external drives, or if you've added a special fan. Otherwise the computer usually has 3 fans - one for the CPU/Heatsink, one in the Power Supply, and optionally a case fan for general cooling.
I hope that helps - if so, please rate my solution, if not, please post additional questions to this problem and I'll continue to help you resolve this issue.
Good Luck,
airoff
Fan noise
Hello. Your statement is FAN NOISE. If you are asking information about the 500GB hard drive, there is no fan IN the hard drive. If you are asking about a fan on a motherboard or case, then those can become dirty and need blown out with canned compressed air. The bearings can also be worn out after much use and the fan(s) would need to be replaced with the same new.
Hope this helps..
Nov 02, 2012 | MSI 500GB Hard Drive for CR400, CR410,...
REAR FAN FAILURE DELL OPTIPLEX 755
This is the rear fan
Replacing a Hard Drive Fan
  1. Follow the procedures in Before You Begin.
  2. Remove the computer cover (see Removing the Computer Cover).
  3. Remove the hard drive (see Removing a Hard Drive).
  4. Turn the hard drive upside down, so that the hard drive fan is visible in the bottom of the drive bracket.
  5. To remove the hard drive fan:
    1. Lift the release tab on the back panel of the fan.
    1. Rotate the fan in the opposite direction from that indicated by the arrow on the back panel of the fan.
    2. Lift to remove the fan and its back panel from the hard drive bracket.
klamma16.jpgReplacing a Hard Drive Fan
  1. Follow the instructions in Before You Begin.
  2. Remove the hard drive (see Hard Drive).
  3. Remove the hard drive fan:
    1. Remove the screw that secures the fan release tab to the hard drive bracket.
    1. Press down on the fan release tab, and then slide the fan towards the front of the computer so that its side tabs are free of the corresponding slots in the hard drive bracket.
    2. Lift to remove the fan from the hard drive bracket.
    3. Unplug the fan.
May 30, 2011 | Dell Optiplex 755 Ultra Small Form Factor...
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
E68 Error Please Help
Turn off system, take hard drive off, put hard drive back on, turn system back on.
Dec 18, 2009 | Microsoft Xbox 360 Console
Just got a new 3 games for my 360 and now it shows E68 along with the red circle eye or death lol. Can't play my game please help
Hi Chris
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
check if after removing the drive if you still get the red light error or not, if the red light issue still prevails please send your console to MS support for repairs
Nov 24, 2009 | Ubi Soft Video Game Consoles & Games
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
My computer makes a loud noise,how can I fix this problem please?
there are a limited number of things that could be making noises. take off the cover of your computer and listen close when you start it. A fan would be the first thing i'de suspect. check them all- cpu fan- motherboard fan-videocard fan- powersupply fan.
I would also listen to the powersupply (rear top of computer)
only things left to check that could be making noise are the cd/dvd rom, floppy drive (both wont run without a disk in them) and your hard drive which would be the last one to make noise. the hard drive runs everytime your computer moves data, if it is getting loud, i would suggest backing up important files and shopping for a new one. Post again here if I can be of further assistance.
Regards..
Apr 06, 2009 | E-Machines eMachines Desktop PC
Dell dimension 5000 won't start
I hate to say this but it sounds like your hard drive has crashed. I would purchase another for about 80 dollars and reinstall windows.
Apr 05, 2009 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Computer is freezing
hi friend
if u have insatll ur new hard drive then is not ur hard drive problem ur pc prosser over hiting rpoblem so chk the ur porsser fan its not working proper or the prosser fan is not conneted or its not working proper or dust in ur fan so clen ur porsser fan by the the dust if u have proper knowlage of how to open ur laptop then will u open if u not have a proper knowge how to open ur laptop
if not have a proper knowlage of open ur laptop then u have go good tacnision he will clen ur prosser fan ur laptop is working proper again
Mar 31, 2008 | Toshiba Satellite P105-S6024 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
