Question about Kenwood Radio Communications
Cloning What are the instructions for cloning the two-way radios using a cloning cable?
  • Kenwood Master
  • 1,654 Answers
The methods differ by model. Contact your local Kenwood dealer to see if they can recommend the appropriate method for your Kenwood model.
Posted on Aug 16, 2008
Clone Motorola BPR40 with PMDN4060AR, but I'm getting a low continual tone from the slave radio from Ch 2 above
Even with a cloning cable, you cannot always clone. The source radio and receiving radio must (1) be the same exact model, (2) have cloning enabled in the software a dealer used when they were programmed the first time. It sounds like you are doing the correct procedure.
Nov 18, 2015 | Motorola Radio Communications
Can I clone 888s from another I have programmed with cable
With the cable specified by the manufacturer, you may be able to do so. Many people have had problems "cloning" the Baofeng radios. Their instructions are not very clear. You may find better informatin if you GOOGLE the instructions for that radio.
Aug 15, 2013 | Baofeng BF-888 S UHF 400-470 MHz Portable...
I just want to know how to clone the motorola rdm2070d
You will need the RLN6303 RDX Radio to Radio Cloning Cable, or two drop-in chargers, or the multi-unit charge tray. Instructions for cloning are on page 51 of the user guide: http://www.weatherconnection.com/manuals/RDV5100.pdf Best regards.
Jul 08, 2011 | Motorola Mag One BPR40 Two Way Radio
Motorola XTNi off frequency
There are several ways:
1) Customer Programming Software (CPS)*
Allows users to perform various programming
functions. Plus, the CPS software provides access
to new features such as Radio Reporting to
manage cloning and radio profiles, Manager Lock,
Power Select, and Time-Out Timers.
* CPS is available as an optional accessory, including required USB cable.
2) Easy Cloning
Quickly copy settings from radio to radio with
either the Radio-to-Radio Cloning Cable or the
Multi-Unit Charger accessories. (Both sold
separately.)
You should be able to purchase any of this software/equipment from your retailer where you purchased the radio.
Best regards.
Dec 03, 2009 | Motorola XTN 2-Way Radio
I require the manual for cloning instructions for the motorolla HT-600, where I can find it. And with the Cloning Clone Cable for Motorola MT1000 HT600 P200 can i clone the frequencies on a radio and...
Now, you can find different types of clone such as Gaming, E-Commerce, Social Media, Music, Digital Marketing
for all purpose.
You can try Best of Clone scripts site to improve your work and business so it may helpful for you.
Nov 09, 2009 | Motorola For MT1000 MTX800 MTX90010v...
How do I use a cloning cable to program a hand held MT1000
Cloning Procedure:
(The content of radio A is to be duplicated into radio B)
1. Turn off radio A and turn on radio B.
2. Connect the cloning cable (NKN6376A) to the Universal Connector of both radio A and radio B.
3. Place the PL switch on radio A to the carrier squelch position for full cloning, or the PL position for partial cloning. Full cloning will duplicate the content of radio A to radio B, except for the deviation and squelch settings. Partial cloning is recommended due to deviation variations from radio to radio. (Later version MT1000's (B model for 6, 16, and 99 channel portables; A model for 8 channel) have partial cloning.)
4. Simultaneously depress the PTT and Monitor button on radio A and hold.
5. Turn on radio A. The green LED turns off. Release the PTT and the Monitor button on radio A (HT600's and older MT1000's (A model for 16 and 99 channel portables) beep when cloning is complete). Turn radios "off and on" to reset.
6. Cloning is complete once the green LED turns off. Release both the PTT and Monitor button on radio A. Turn radio A off and on to reset.
NOTE:
For MDC front covers (NTN5456, NTN5457, NTN5458, NTN5459, and NTN6009B), make sure that radio B is turned on before it is connected to the cloning cable.
NOTE:
All VHF wideband radios (146-174MHz) are "C" model radios. A "C" model radio can be cloned only to/from another "C" model radio. An attempt to clone a "C" model radio to an "A" or "B" model radio will result in an unsuccessful cloning attempt.
Any unsuccessful cloning attempt (depending on operating condition of the radio) will result in one of the following alerts:
1. in receive (rotary radio) - 1600Hz continuous alert tone
2. in receive (display radios) - 88 displayed on LCD
3. in transmit - 1600Hz beeping alert tone
Nov 04, 2009 | Motorola For MT1000 MTX800 MTX90010v...
Motorola BPR40 how to clone
How To Clone a BPR40 Radio
Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio.
2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice.
3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio
2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times.
3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures
1. Connect the cloning cable to both the Master and Slave radio.
2. Press and release Programmable Button 1 of the Slave radio.
3. Within 2 seconds Press and release Programmable Button 1 of the Master radio.
4. The LED for both radios show flashing orange during cloning.
5. Once cloning is completed, an
Mar 24, 2009 | Radio Communications
Vertex 180 cloning
from my own experience, vertex customer service in california has been excellent. try giving them a call. 714-827-7600
Feb 20, 2008 | Radio Communications
Motorola GP2000
http://www.batlabs.com/gp2000.html
Cloning
These radios support cloning parameters between a master and slave radio.
Cloning only transfers the user's settings from the master radio to the slave. Things like tuning values, serial number, etc. are not changed.
To clone a master radio to a slave (target), perform the following:
    • Make sure both radios are off
    • Connect the cloning cable between the two radios through the programming port
    • Turn on the slave radio
    • Press and hold the "A" button on the master radio and turn it on
    • The master radio will display CLONE if cloning can proceed, otherwise an error will be displayed
    • The slave radio will display PROG while it is being programmed
    • When cloning is complete, the master radio will display END and the slave radio will reset automatically
    • Disconnect the radios from the cloning cable
Feb 15, 2008 | Motorola Multi Unit Charger with Cloning...
Radio Communications Logo
154 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
