Question about Kitchen Ranges
Jenn air 88370
On my jenn air 88370 range I have a setting on the dial called Accel Clean. There is no manual with this range as it was in the house when I purchased it. Do I have a self cleaning oven or do I have a continuous cleaning oven or what. Can someone help me or tell me where I can get a manual for this range. I tried Jenn Air but they say it is too old (pre 1980) and they don't have the info in their system anymore. Appreciate any help you can give me. LindaR
  • jayhawk1988 Nov 29, 2008
    I have the same problem. The unit is a Jen-air convection oven 88370 model purchased in 1980 according to the documents that were left in the house when we moved in in 1995. I do not know how to clean the oven. No instructions and can not find anything online.
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Posted on Feb 28, 2009
We purchased an older house that has a Jenn Air D120 Electric Range but no manual to tell me how to use it. Does anyone have one they could scan and send me?
Hello Barbara,
Simple search online will get you to jennair.com
or
You can search within
Guides & Manuals, or call a Customer Care Specialist at 1-800-JENN-AIR (536-6247).
or
kitchen.manualsonline.com
Good luck and all the best in your new home.
Nov 14, 2015 | Jenn Air Kitchen Ranges
Jenn Air Range Model 88370 oven only bakes in the back and leaves food raw in the front.
It will be the oven element that has failed, a new one wiil need to be fitted.
It is located at the rear of the oven compartment behind a removeable cover.
I hope this helps.
Apr 11, 2010 | Ovens
Installing Jenn-Air 88370
Jenn-Air.com/ Support online can help you
Apr 22, 2009 | Kitchen Ranges
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Accel Cleaning Setting
It's 'sort of' self cleaning. I just got done figuring it out. If your clock still works, you're supposed to set it for one hour of cooking. Turn the Selector to Accel Clean and the thermostat to 550. The oven fan should come on and the elements should heat. The door doesn't have a lock, which must explain why it only 'cleans' at 550°F.
Jul 28, 2008 | Kitchen Ranges
Jenn-air oven model #88370
its just not that often the probe fails without setting a code
Feb 16, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn Air 88370
You need a new knob part y715403 . Turn knob clockwise first clik should be bake position
Jan 08, 2008 | Ovens
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
959 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
