Keurig B60 Coffee Maker Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I use the reusable filter, I get coffee grounds in my cup. This was not happening in the beginning. I have been using the same filter about six months every day. Is there a solution?
Anonymous
Level 2:
New Friend:
  • Expert 43 Answers
  • Posted on Feb 26, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
43
Questions
0
Helped
4568
Points
133
Filtru montar rau , remont dupa curatire!
How do I order a filter for my Keurig?
You must be more specific about "filter".
Are you inquiring about the "My K Cup" reusable wire mesh filter to use your own ground coffee? You can order them online through Amazon. Here's a link:
http://www.amazon.com/Keurig-K-Cup-Replacement-Coffee-Filter/dp/B009VIUI04/ref=sr_1_6?s=home-garden&ie=UTF8&qid=1442776181&sr=1-6&keywords=Keurig+filter
If you're asking about Keurig charcoal water filters, here's a link for that on Amazon:
http://www.amazon.com/Charcoal-Water-Filters-Replaces-Keurig/dp/B00HL2ZR2Q/ref=sr_1_6?ie=UTF8&qid=1417372516&sr=8-6&keywords=keurig+filter
Hope this helps. Thank you for using Fixya!
KEEP IT FROM LETTING THE GROUNDS OVERFLOW FROM THE KCUPS
If the coffee grounds are overflowing, you can try using less if a reusable mesh filter is in place. If it's just a disposable K-cup you're using, the recommendation is to use each one only once to prevent this.
Keurig
LIKE DRINKING WATER WITH A HINT OF COFFEE
You have 3 selections, thus use #1 or #2 for a stronger brew. Naturally the water levels will differ. Get a Reusable Kcup device and pack your own coffee for better results. Get fine ground coffee or grind your own, and then pack the Kcup reusable with your grinds. A fast hot water flow is excellent.
Husband brewed coffee using reusable filter without the lid. Grounds everywhere. Is it possible for the grounds to have made it to the 'guts' of the unit? Should I disassemble to clean?
Just clean as per the directions in the manual. Get a reusable cup with a rubber seal around the lid and do not fill to the top, leave room for the top to close and seal.
5helpful
When using the reusable filter the coffee spews out in all directions with some of the coffee grounds
I googled this problem for 3 days. I was reluctant to try anything that would screw up my machine, as I have been very happy with it, except for the re-usable filter performance.
I wiggled the o-ring washer around top sharp thingie by maybe 1/8 inch and that fixed it. K-cups are running normal as well.
4helpful
How do I make my own coffee in the Keurig? I have the reusable filter, but I don't know how to use it.
Sorry to read about your problem, I hope this helps you out.
No problem, you will goto the maker, and open the latch, as if you are going to put in a k-cup..
Well that little brown holder, comes out..use 2 fingers and try to snap it out...when you get it out. put in the reusable filter..and you are done
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
2helpful
I broke the peice that puts water through the coffee basket on a Keurig Elite B40 Coffee Maker where can I buy parts for this?
If you are talking about the K-cup holder that punches the bottom of the k-cups, they usually are not for sale, and you can only find them on ersale sites like Ebay.etc...
you could also go buy a "Keurig My K-Cup Reusable Coffee Filter"
and just use the main grey plastic filter holder... but you will have to puncture the bottom of the k-cups yourself before dropping them into the holder...
You wont need the filter basket or the lid if your using k-cups... just the filter holder...
dont forget to punch a hole in the k-cup first...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
1helpful
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
