Sony kp53v80 Red convergence stuck vertically
Used your advise to try and fix my red convergence issue. I can adjust all colors both vertically and horizontally except RED...my problem. Can adjust it horizontally but not vertically. And vertically is where my big problem is. It's way...way off. Happened overnight. Is there a part I can replace myself or solder to fix this myself? Old TV but love it. Any advice would he helpful. Thanks so much, Lou
  • 2 more comments
  • LouB747 Jul 28, 2008
    Gonna take a look inside today. Have 2 small kids so getting free time is hard!!! Are there 2 convergence IC's for each color? I'm assuming without looking that there is one for the vert and one for the horizontal for each color. Also assuming without looking that the pico fuses you mention would be close to the IC. Reading I found that the IC is part: STK-392-040. Will have a look soon. Thanks for your quick reply. Have basic electric understanding but may have problems identifying the parts you mention. I read the pico fuse in "orange" and marked "Fxxx" Assuming something blew based on the fact that the vert will not adjust at all. Thanks again, any additional info would help as far as location of the resistors you mention......thanks again..Lou
    Yes, saw the 392-150. Thanks for the link. Can't find the 2.2 1/2 watt resistors. They have 2.2 1 watt. Will those work? Looks like I'll have to pull the board for the soldering. Hope it's not too hard to take out/put in....Thanks again. Will order the parts after I hear from you......Really appreciate your help..Lou
  • LouB747 Aug 04, 2008
    How do I remove these wires so I can solder??
  • LouB747 Aug 05, 2008
    After awhile labeling all the wires, I got the board out. Soldered in new parts. TV works great!!!! As if new. I can't thank you enough.........Lou
  • 8,617 Answers
Did you replace the convergence ICs? The 4.7 ohm 1/2wwatt resistors and the pico fuses? Let me know and I will assist you, as often sonys will blow the 3.5 pico and a few of the 4.7 ohm 1/2watt resistors when the Ics fail.
Posted on Jul 28, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Jul 28, 2008
    If your model number is the KP53V80 your model uses two STK392-150 convergence Ics twelve 2.2 ohm 1/2watt resistors and six 2.0Amp pico fuses. Those are the items most likely needing replacement. You can get replacement parts at the following link with free instalation instructions with free tech support. Here is the link.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry Jul 29, 2008
    They dont list all the resistors they have, but if you order the 2.2 ohm 1 watt leave them a comment that you want the 1/2watt instead of the 1watt, Or you can email them when they send you an order confirmation. They will help you get the board out as well> Just ask them and they will send the instructions with illustrations to get your board out. They are a good site , they go the distance to help you repair your set.
  • Sonny Berry
    Sonny Berry Aug 05, 2008
    Unhook the large one from the other end at the HV splitter and the small one also disconnect at the other end which is the focus screen control
  • Sonny Berry
    Sonny Berry Aug 06, 2008
    Feels good to have saved about 600.00 on a repair thats not that difficult doesnt it?. Glad I could help you out. Congratulations on a good repair job.
Fixing color convergence red and blue lines
most TVs have an adjustment for convergence in your on screen menu, go into convergence of service menu & try to adjust; it it is still too far out of convergence contact a service technician as convergence issues can be very difficult to resolve unless you are very sure of what you are doing.
Dec 26, 2014 | Televison & Video
Hello i have a sony KP-46WT510 model 45" TV, and
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc
Feb 18, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    The red color seems to be sperating itself from the actual picture. The logos on screen are showing up as double image. pls advise what could be the problem
    This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
    • Screen looks 3D
    • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
    You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
    69189a5.pngCONVERGENCE SOLUTION
    You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Aug 14, 2010 | Sony KP-51HW40 51" Rear Projection...
    It appears to be convergence issues. Red, green,
    Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
    Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
    93a1209.pngCONVERGENCE SOLUTION
    This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
    May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
    My TV is red and green in 3D--what needs to be
    Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a Sony convergenece repair kit from the link below.
    • Screen looks 3D
    Their kits include a step by step instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
    BEFORE
    AFTER
    93a1209.pngSolution #2 - CRT FLUID FIX
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
    Feb 07, 2010 | Sony KP-46WT500 46" Rear Projection...
    RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
    The most likely cause is shorted convergence chips and possibly a few pico fuses.
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
    When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
    You can get a convergenece repair kit with instructions from the links below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms...
    *Screen Looks 3-D
    *Colors wont align
    *Screen may look distorted or warped
    *No Audio/Video - TV Shuts down - May also make a constant chirping sound
    Problem #2
    Another common problem is dull or washed out video.
    Your set may have one or more of the following symptoms....
    *Dull looking picture
    *White looking picture
    *Halos around objects
    *Red/Orange looking picture
    You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
    Rear projection convergence issues
    Projection TV sets have several common problems listed below.
    Symptoms:
    • Screen Looks 3-D
    • Colors wont align
    • Screen may look distorted
    • No Audio/Video - makes a chirping sound.
    Example Photo:
    Problem #2 CRT Fluid has clouded over.
    Symptoms
    • Dull Video, Washed out
    • White/Bright looking video
    • Halos around objects
    • Red/Orange looking
    Example Photo:
    You can see more examples and find a fix here...
    Apr 24, 2009 | Sony KP-53V80 53" Rear Projection...
    Televison & Video Logo
    557 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
