Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
PAC L90 water tank capacity
With the PAC L90 how long will the unit run without draining the tank. I have it setup to constantly drain, should I plug the drain hoses to get colder air? Do I drain or let fill for cooler air?
  • 750 Answers
When tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
How to drain water
This AC unit has no tank to empty or drain line for it to run.
May 22, 2014 | DeLonghi PAC C100 Air Conditioner
I have a comfort aire pac-121 and the display is reading e4 and the ac is not working. i can't find a manual on line. How can I fix the problem? thanks andy
I have the same model, though several years old, and on mine E4 simply means the reservoir is full. Try emptying the reservoir tank and then turning the power on again. If the drain hose outlet isn't angled down, the water drains into the tank, which will need to be emptied regularly. (For constant use, may need to be emptied several times a day.)
Jan 15, 2011 | Comfort-Aire PAC-121 Air Conditioner
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
Help please...blinking FE but E does not have top line to the right
Check that the error is not Ft, that means Full Tank.
Drain the internal safety tank through the drain hoses by opening the cover on the rear of the appliance.
there you will find two drain hoses,pull them out, take off the caps, and let all the water flow out.
When finish draining the water place the caps and the hoses back in place.
You also need to clean the filters and let them dry before putting them back in place.
Here is the user manual, see self diagnosis section.
Sep 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
How do i empty the tank
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, fe shows in the display how do you empty the tank.
This is the user manual site.
scroll down to the diagram on page 16 and they describe how to empty the water from the system
http://www.delonghiusa.com/manuals/PACL90.pdf
To empty the tank on the rear of the
appliance.
Pull out the 2 drain hoses, take off the caps
When all the water has been drained, place
the caps back on the hoses and put the
hoses back inside.
Clean the filters and dry thoroughly before
putting them back.
Remember to give me a solved rating before you log off!
Thank You Huuum
Aug 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Narrow tube v. plug and cap?
If the unit stops working and some kind of a 'water level full' indicator appears then un bend it and un plug it and then let the water drain into a bucket.  If it continues to indicate that the internal water tank if full you may want to run a hose to a drain in the floor or into a bucket to let the water drain away and the unit keep running without stopping.
Jun 13, 2008 | Windchaser PACR10 Portable Air Conditioner
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
FE Light
You need drain the water and then function normally.
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
443 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
