Question about Panasonic TH-42PX75U 42 in. Plasma Television
TV antenna I jusjust cancelled my Direct TV because I can't get any channels and they can't service it until the middle of August. It is a pain in the neck and always going out anyway, even with just a little rain. We are thinking about getting an antenna and going with local channels only as when we are home we usually watch movies anyway. Where and what type of antenna do I get? We have big screen plasma set that we bought 2 years ago. Is it ready, or do we need to get a digital converter box before next year? We had to buy a Direct TV HD reciever along with it, which we have never connected. Is this still useful to us? Thanks Patti
  • splhcb Jul 29, 2008
    Thank you!
    Scholar:
  • 78 Answers
Hi splhcb,
Your television is already an HDTV, meaning it is set up for receiving digital broadcasts. In this case, you should not need a separate converter box for over-the-air reception. You will need an antenna, but the type you purchase depends on things like how far you live from broadcast towers, landscapes, buildings, and where it will be located in your home. Although many antennas are being marketed as HDTV compatible, if you already own an antenna you likely can continue using it. Otherwise, it is best to speak with someone at the store who can weigh the factors in your situation to recommend the best antenna.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jul 28, 2008
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
I cancelled my cable and switched to Netflix. I'm trying to set up an antenna so I can grab channels 6, 10. and 12.....but I can't find a TV Antenna that will grab service to access these...
First, you can only get digital channels now,so you must have a tv that can receive digital. You can buy digital tv antennas that can receive about 70 miles that mount outside or in your attic. This FCC site can show you where to point the antenna to get the best signal:" https://www.fcc.gov/media/engineering/dtvmaps
Also you can get a signal booster that will help if you can get a minimal signal. The booster will only amplify a signal so if you cant get one at all it won't help.
Feb 17, 2018 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
Feb 28, 2009 | Sansui 27" TV
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Panasonic TH-42PX75U 42 in. Plasma Television Logo
205 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
