Samsung Digimax A400 Digital Camera Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a message on my digimax A400 screen stating CARD LOCKED can u help plse?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Samsung Master 102,366 Answers
  • Posted on Mar 01, 2013
Samsung Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440282
Points
622693
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
5 Related Answers
A
Anonymous
  • Posted on Nov 05, 2007
SOURCE: card locked
Take the SD card out and unlock the card by moving a small slide on the side of the SD card, sometimes you can accidentially lock it when re-inserting the card.
Mark Snell
  • 86 Answers
  • Posted on Jan 13, 2008
SOURCE: card locked
Most SD Memory cards have a little switch on the side to lock them, try switching that to the other position.
Vic Fkiaras
  • 18 Answers
  • Posted on Dec 09, 2008
SOURCE: my camera says card locked
Check the side of your media device, it will be locke.
See pic: http://en.wikipedia.org/wiki/Image:SD_Cards.png
Slide the little switch to the unlock position.
Anonymous
  • 180 Answers
  • Posted on Feb 20, 2009
SOURCE: "Card Locked"! appears when trying to take a picture.
a little switch on the side of the memory card
The Jed
The Jed
  • 42 Answers
  • Posted on Mar 26, 2009
SOURCE: mislaid instructions for Samsung Digimax A400 camera
You can find the manual in PDF format here:
http://downloadcenter.samsung.com/content/UM/200802/20080225143127765_A400_English.pdf
I have a Casio Exilim EX-Z80A and it shows that the SD card is locked. I tried sliding the thing on the side of the card, but nothing. I even put in a different card, but it still shows Card Locked! Please...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (note 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
1helpful
Don't have a cd for my Samsung Digimax A400 camera?
Hello
no problem, go to the website: http://www.samsung.com/uk/support/download/supportDownMain.do
and follow the instructions on screen to find your camera and it will give you an option to download the drivers and other software avalible for your camera.
Good Luck, and do rate the solution if got help
I am unable to take photos with my samsung digimax s800 camera as the message 'CARD LOCKED' keeps coming up on screen. I have deleted loads of photos so the memory card is definitely not full. Any ideas?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Error message showing 'card locked' Help
Move the slide switch on the side of the card.
2helpful
Mislaid instructions for Samsung Digimax A400 camera
1helpful
My camera says card locked
Memory card problem
Are you sure you have the right type of memory card? Make sure you use an SD/MMC card. You might try another SD card.
Is this a new camera? I bought one once and the card slot was defective. I took it back right away, rather than trying to force a card into it.
Mike
Lcd monitor
THE DISPLAY LIGHT DONT WORK YOU NEED TO GET THAT PART
Samsung digimax a400
did you sister give you a manual[book] or software disk? thats to place to Start.
2answers
Card locked
Reformat card - have you tried? Check your manual seek help in Samsung Web site Come back if still int rouble
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
