Question about Brother IntelliFax-2820 Laser Fax
Intellifax-2280 We are hearing a grinding noise from this unit. It is less than a year old???? Please advise
    Sergeant:
  • 329 Answers
Brothers have a year guarantee take it back to where you purchased or call Brothers. Do not know model, grinding many times come from fuser, or drum cartridge and on many models toner cartridge....
Posted on Aug 28, 2008
My Iveco eurocargo 75e16s tipper has a very noisy air compressor unit can you tell me if it needs fixing?
some times better to fit a refurbished unit
noises like that means might fail soon
Sep 11, 2016 | Cars & Trucks
Should I lubricate my fan to stop a grinding noise?
Most hunter fan don't require lubrication, if you hear a grinding noise I would check the balance of the fan, if your hearing a grinding, and its not caused by being out of balance, then I would replace fan
Jan 09, 2015 | Hunter 23852 Classic Original Ceiling Fan
Rtw4340sq0
Sounds like bearings are shot!!!call warranty company, let them sort it,,,it's normally quite expensive
Jun 17, 2013 | Washing Machines
Mazda grinding while braking.
Hi, i would chk your rotor on the wheel your hearing the noise from. Sounds like a brake pad has worn out and is chewing your rotor. That can cause all your issues. Hope that helps
Jul 12, 2017 | Mazda Cars & Trucks
My kenmore gas dryer model 110-76662501 is making a thumping noise while the dryer is running. The dryer is about 5 years old used about 3 times a week. The clothes dry fine. Maybe a pulley or...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 11, 2011 | Kenmore Dryers
Load grinding noise, like the engine is working too hard.
Most likely the motor/pump assembly is worn out and grinding. If the machine is less than five years old it is under warranty. If over five years old, the repair part alone is about $150 not including labor.
Apr 17, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher making loud noise
Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
Jan 10, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
Ptac
You need a new control board. The relays go out on these. If your unit is less than a year old then you should still be under warranty. Unless you did not send in the warranty card, then the company only warrants the unit for 1 year after the mfg. date. You will need to provide the serial and part number to find out from Amana. The new control boards are much better by the way, and worse come to worse, they are only $130. Please let me know if this has helped in any way.
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
151 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
