Question about Lexmark MFP-X3470 All-In-One InkJet Printer
Cover open Put in new ink cartridge, then "cover open" came on and everything froze up. Found the small white plastic piece loose inside. Now what?
You have to take the whole lid off. There's a small white plastic thingy on the right side that touches something to tell the printer the lid is closed. Sometimes, it comes off. It's not attached very well. If you don't see it, then you might have to turn the printer upside down and shake it!
Posted on Jul 31, 2008
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Getting 6C10 error on my new Canon MG5220... I have tried everything and it won't go away. Any suggestions.
turn off the printer.
Press and hold the resume button and click and hold the power button.
While continuing to hold the power button, release the resume button.
Still holding the power button, click the resume button 2 more times.
Release both buttons.
Click the resume button 4 more times.
Turn the power off then on.
Dec 21, 2010 | Office Equipment & Supplies
I changed my ink cartridge, and now it has cover open displayed but the cover is closed
when you open the lid there is a small white piece of plastic witch should be attached to a very small micro switch .this keeps coming off for some reason .you have to find it and reattach it to the switch that is just right of the middle of your printer .hope this helps
Oct 02, 2010 | Lexmark X3480 All-In-One Printer
Brother mfc240c not detecting black ink cartridge. When I remove the cartridge and replace it with another it will not detect that the cartridge has been removed.
on the ink cartridge, midway between the two holes that plug into the printer, there's an opening. evidently, the printer senses ink level thru the little piece of plastic.
with printer OFF, take all ink cartridges out. cut small pieces of duct tape, small enough to cover the hole but not pass the catridge edge. use a small screwdriver or tip of a knife blade to work the edges of the tape into the slot, covering the little plastic window.
insert back into printer. worked for me. it's simpler than it sounds.
Jul 27, 2010 | Brother Multi-Function Center MFC-240C...
Printer sat unused for one year while my husband and I were both away on military duty. Returned to find that despite replacing all of the ink cartridges the black ink will not work. I performed self...
Jul 22, 2010 | Brother MFC 240C All-In-One InkJet Printer
I put in a new color cartridge and i keep getting a message you need to put in a new cartridge. but I already did
A common problem with ink cartridges are the plastic strips that protect the cartridge terminals. These strips are so thin that they can easily break,leaving a small piece covering the cartridge head. If this happens the printer cannot read that a new cartridge is installed.
Remove the cartridge a double check that all of the protective plastic tape is removed. If that fails, try unplugging your printer and wait several minutes before plugging it in again.
Mar 24, 2010 | Canon Office Equipment & Supplies
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
After installing a new ink cartridge my display shows cover open and the cover is closed therefore I can't print
did you take off the cover of the ink cartridge
IF it is ok
Please reinstall the printer driver
Nov 07, 2008 | Office Equipment & Supplies
MFC240C
bye, bye mfc...
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000087/faq002487_000.html?reg=us&c=us&lang=en&prod=mfc240c_all
May 22, 2008 | Brother MFC 240C All-In-One InkJet Printer
Open Questions:
Lexmark MFP-X3470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
