Sometimes my Flat Panel monitor will cut on and sometimes it goes on the blink; it acts as if it is not gettting power. What can tis be?
  • 177 Answers
Check your cable connections.As these tend to become loose after a while.
Posted on Jul 28, 2008
Keeps turning off
Everytime I worked on this set I have found bad connections in the power supply or on one of the inverter transformers
Dec 31, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
My monitor was not power on inspite we already corrected. and sometimes the power on was blinking in light.
I encounterred that same problem before. I just changed the video card cause it was corrupted.
Jun 18, 2011 | Samsung Syncmaster 730B 17" Flat Panel LCD...
My monitor is about 6 years old. Some weeks ago, when I powered on, a grey streak started appearing and moved top to bottom before the normal image came on. Lately, the monitor blinks on and off when I...
2003 is the first one made, 14 years old it sure can be.
new to you sure,.
all monitors, from 2000 to 2010 year, are backlighted with
crude CCFL maps, that last for 2 years (shortest life full time)
the all go bad, ever one , if USED, lots.
they all: endup soon.
1: dim
2: yellow tubes.
3: flicker ands strobe (not the data just the back lamps)
4: dead.
5: totally interminttant.
just like the forecent lamps im garage and for the same reasons.
6: the osd goes dead to when above happens. menu key on monitor front, but not data seen with flash light trick.
learn when 4 happens, above, do this.
http://pcdied.com/monitors.html#flashlighttest
manual.
https://www.manualslib.com/manual/30069/Hp-F1523.html#manual
buy monitor 2011 and newer, and this pain above goes byebye
at the introduction of wonderful, LED backlamps.
Oct 16, 2017 | HP Compaq FP 7317 17" Flat Panel LCD...
Dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
http://josepino.com/other_projects/?howto-repair-dell
goo dluck if you want it fixed for you let me know
Mar 22, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell e171fp + turn off after a second
hi, are you able to browse thru the LCD menu, there must be some settings for power management.. let me know?
bye
Dec 15, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Green power light blinks every 3 seconds with the word Xerox on the screen, with just a black screen. Could this be a bad Switching Power supply cord?
open it up... whats the worst that could happen... see if the caps are fine... if they are bloated exchange them... if you need help doing so hit me up at abelino24(at)sbcglobal(.)net... I've repaired like three of these in the past few months.. its always the capacitors. they either get really hot and bloat or don't function if it gets too cold... so the solution if to get the right caps at 470uf / 25v and 220uf / 25v... hopes this helps...
Nov 18, 2006 | Xerox XG-71D 17" Flat Panel LCD Monitor
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
