Question about Whirlpool Duet GHW9150P Front Load Washer
F-21 error im having the same problem my machine wont drain PLEASE let me know how you fixed it :( thank you, Janet
  • 770 Answers
No f21 code but there is an F2 which is long drain remove the lint filter behind the bottom panel and check for a blockage first
Posted on Jul 30, 2008
Error 21 was on washer, we cleaned out drain then started washer it appeared to be working, but then error message 21 came on again. It is very late so tomorrow morning we will open drain again.
Hello, it can only be dirty filtersomething in the pump drain line blocked up or failed pump. I would check the filter again and if its clean put the drain hose in a bucket see if it drains but chances are you will need a new drain pump. hope this helps please rate my answer thanks
Jun 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wont drain or spin & has F-21 flashing on screen
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loading whirlpool stopped part way through wash with a F 21 error message. Please advise. Thanks; Kelly
Hi Kelly,
Thanks for using FixYa. Error F21 means long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Washing Machines
My whirlpool duet is giving a code of F 21. what does that mean and how do i fix it?
Hi
Thanks
Rylee
Jul 18, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F-21 machine will not drain or spin
Hi
Thanks
Rylee
Jun 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Mar 29, 2010 | Dishwashers
F 21 error code I came down with 1 minute estimated time remaining, and it was still spinning with soap and water in the machine. I checked again 20 minutes later and the water and soap was still in...
"F21" is a long drain error code. This is most commonly caused by something obstructing the drain pump, or drain lines. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
I would begin by checking the drain pump reservoir for small debris. You would be amazed as to what finds its way into these pumps. The link I provided also gives instructions on how to check the drain pump.
If you clear the drain pump and the problem still presists, verify all the drain lines are clear. If all these preliminary checks still result in an error code, more than likely the drain pump is damaged and requires replacement.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2plus wont spin...F-21 error
Apparantly the F21 error means there is a drain problem...I removed the drain hose from the output in the wall and held it down at ground level and let it drain into a pot...I ran the rinse, drain and spin cycle while I did this but before I hit the start button I hit the 2nd rinse button to turn off the rinse portion of the cycle. It seems to be draining fine now.
Jul 01, 2008 | Washing Machines
Sanyo vpc-e760 digital camera
i have the same problem ..
it was error 16 AND 21 .
im not entirely sure about the error 27 or any other
numbers ;
but i do know for a fact its because there
is something like dirt ; hairspray ; make up etc.
in the lens .
idk how to take the camera apart ..
but your best luck is to kind of jar your camera with your
palm or a book or something .
mine fell on the floor at first and was fixed ,
but today i dropped it in a little bit of sand and hasnt gone
back down yet .
im hoping i can fix it :/
let me know if any of you have any luck .
Mar 02, 2008 | Cameras
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
