Question about Kenmore 63942 Dryer
Ok but where is the darn thing (thermal fuse) Kenmore 84052500 dryer
And how do I get to it?
    Novelist:
  • 177 Answers
You need to unplug the dryer
Then pull the dryer out from where it is.
Remove the back panel.
On the blower housing, lower left side
White piece of plastic. two wires to it usually pink or purple, usually held in with one screw.
Vacuum up all the lint.
Put back panel on.
Plug in and try dryer.
Next time thermal fuse opens, replace dryer
Posted on Jul 29, 2008
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
My name is Peter. I am a retired field service appliance technician.
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
I have a Kenmore 800 model no. 110.69822801 dryer that stopped during a drying cycle. It would not start. I found helpful tips from your site and decided the door switch was faulty. I bought a new switch...
Check the thermal fuse, check the belt switch. If these are OK, check the timer. The timer troubleshooting guide may be located within the control panel. If the dryer still doesn't turn on, check motor winding continuity, and finally control board. Perform these checks with dryer unplugged. Most likely causes: Thermal fuse or timer. If thermal fuse is problem, clean dryer duct after fuse replacement.
Dec 18, 2014 | Kenmore Dryers
Kenmore Model 1.10 60902990 Dryer Problem
Try it with out connecting to your vent and see if it still trips,other wise your vent is still clogged. Also should be good air pushing out the disconnected vent, if not maybe blower wheel clogged.
Another thing is how hot is it getting.Maybe the operating thermostat is getting to hot and never stopping the heat when its supposed to.
Nov 07, 2013 | Kenmore Dryers
Dryer has quit heating
Element burned out, overheat protector failed, switch malfunction. Any of these. Get ohmmeter and start checking.
May 06, 2012 | Kenmore Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
My dryer runs but has no heat. I have replaced the thermal fuse. I have checked the breaker, cleaned out the lint trap and checked the air flow which is good. I do not have a volt meter. Kenmore Electric...
Hello there :
There are severaol things that could cause this to happen
Things to check are :
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
I know that you have checked the thermal fuse so you dont have to worry about this.ok
Hope thatthis is very helpful
Best regards Michael
Dec 23, 2009 | Kenmore Dryers
No heat
its complicated and not able to explain on this page but in any case the unit will have to be completely disassembled and if the igntr bad the thermal fuse ok but more than likely just the thermal fuse....... again its just more work than most people can perform but the first thing is the top has to come off first
Aug 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Kitchenaid superba dryer won't heat Where is the heater fuse located?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuityacross a good element ( 8-12 ohms is an average element ).
But darn it, I don't have a Ohm Meter....
To check the thermal fuse  - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.To check the thermal cut-out  - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity -  - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
How to take apart information for GE style dryers
How to take apart information for Inglis - Whirlpool - Kenmore dryers
How to take apart information for Maytag dryers
How to take apart information for Frigidaire and White Westinghouse
How to take apart information for Admiral, Norge, Magic Chef and Crosley
Mar 30, 2009 | KitchenAid Dryers
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Kenmore 63942 Dryer Logo
169 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
