Question about HP LaserJet 2420 Printer
Not Printing without Pushing Checked Button
When I go to print something, it takes quite a bit of time for the Print dialog box to show up on my computer to select how many copies I want to print off. After selecting an amount of copies I go over to the print and it says that I must push the checked button to process the job. Then I might print out just the first page. But, it never prints by itself or without pushing the checked button. Please help!
  • 138 Answers
Print a configuration page foung under the information menu of the printer. (Hit the check button, scroll to info menu, hit check button, scroll to print config page, hit check button)
Look at the tray menu area on the page and insure that letter (or the size paper your using) and the type (Plain preferably) is listed for tray 2. Next make sure the tray 1 (manual feed tray) is set to any.
If its not as above, go back into the menu at the printer and scroll down to the "paper handling menu" to set up the trays as above.
Once completed, check to make sure when your printing a document that the size shown on the printdriver side under properies (when you hit file print) says the same.
That should clear any waiting to print issues you have.
For the slow printing issues. Read the configuration page to see what the printer has for memory onboard. If you are using a Jetdirect, addional trys (tray 3 or 4) or duplexing it usually takes more memory. Memory is fairly cheap and can be aquired at www.memory.com for just over wholesale cost.
Hope that helps you.
Posted on Aug 03, 2008
The back printing is off, it does print when we run the back printing test, but no printing on the photos, how do we turn this back on, frontier 340
I assume you mean duplexing? Don't know what you're using but on the print dialog screen, just make sure the box is checked for "double sided", "duplex", or "front and back" or something to that extent.
Also, make sure the proper print drivers are installed.
Jun 26, 2014 | Office Equipment & Supplies
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
Mar 11, 2014 | Microsoft Visual Basic 6.0 for PC
In the past I was able to choose the Manual Option which allowed me to print on both sides. Now every time I choose this option, it goes to Off. Can you please help me with this problem?
Many printers support duplex printing, but they don't all make the duplex option available in the same way. With some desktop printers, choosing duplex means that the printer prints all of the copies of the first side of a page, then pauses and asks you to flip the sheets that it just printed and return them to the printer, after which it prints all of the copies of the second side. This method is called manual duplexing.
To print on both sides of a sheet of paper:
  1. On the File menu, click Print.
  2. In the Print dialog box, in the Name list, select the printer that you want to use.
  3. Click Properties.
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
  1. Choose the duplex printing option that you want.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
  1. Click OK to close the Properties dialog box, and then click OK again to close the Print dialog box and print your publication.
Sep 25, 2010 | HP Deskjet 2460 InkJet Printer
HP LASER JET 2605, INSTEAD OF PRINTING PDF, IT IS PRINTING RED TEXT.. AND THE GRAY SCALES ARE RED...
Apparently there is a bug that HP is not fixing. Following is not a solution, only HP can solve this problem but a "workaround" for the time being, allowing you to print the file as image. Keep in mind that the printing will take longer time, because the file is output as bitmap, and that this way of printing it's not good enough for color proofing of any sort.
Check in the specific software Print dialog window, if you can print the file as image. Sometimes the controls are in the advanced options. In Acrobat, check the box for Discolored Background Correction in the PostScript tab of the Print dialog window, and if that doesn't help, check Print as Image check box.
Aug 18, 2010 | HP Color LaserJet 2600n Printer
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
Changing print quality preference
On Windows at least, the print dialog box usually has a "Properties..." button next to where you select your printer. From there, you should be able to choose a lower print quality (Mine gives the options, "FastDraft," "Normal", and "Best"). The lower print quality doesn't look -quite- as nice, but it uses much less ink and takes less time to print as well.
Feb 16, 2010 | HP PhotoSmart C4280 Laser Printer
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Canon mp530 issues with printing
Use scaled printing (Mac OS X) Instructions to use scaled printing. You can manually select the scaling ratio you wish to use to print images and documents. scaling_sample.jpg Note: The Scaled Printing function is not available when Borderless Printing is selected (OS X.version 10.2.1 or higher).
  1. Open the Page Setup dialog box.
  2. Specify the Scaled Printing settings.
    Note: For a reduced scale printing, enter a value smaller than 100 %. For an enlarged scale printing, enter a value greater than 100 %.
  3. Click 'OK'.
  4. Open the Print dialog box.
  5. Click 'Print'.
Printing will now begin.
I hope it helps!!!
Nov 27, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
HP LaserJet 2420 Printer Logo
157 people viewed this question
Seeker5211
Seeker5211
