Desktop has a warning displayed that i cannot get it off thr screen.
  • 177 Answers
Try downloading from Lavasoft.com their latest spyware programme and install. Its free so you have nothing to lose.
Posted on Jul 28, 2008
Why the touch screen not displaying
If thr display is visable but not responding to touch, replace touch screen part #n2
Sep 03, 2014 | Panasonic WORKiO DP-C322 Printer
Tip
DISPLAY YOUR OWN MADE WARNING MESSAGE EACH TIME THE COMPUTER BOOTS!
You can display your own made warning message each time the computer boots. Like "Yous Computer is Hijacked" etc...
All you've got to do is locate following registry key
HKEY_LOCAL_MACHINE\Software\Microsoft\CurrentVersion\WinLogon
search for a string value named
LegalNoticeCaption and LegalNoticeText(create if its not there).
Enter the value of
LegalNoticaCaption "WARNING" and Put the Message you want to Display is the value field of LegalNoticeText.
Next time the windows boots your message will be displayed!
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How do i get my laptop screen thr right way up i pressed somthing and its gone upside down
You probably flipped the screen orientation (rotated it).
For some versions of Windows (XP and Vista), try pressing Control (Crtl)+Alt+Up arrow (press the three keys together). You can also try the other arrow keys with the Crtl+Alt keys. The Crtl and alt keys are both usually in the row with the space bar. On a full-size keyboard, there are two Ctrl keys on the ends of the row and the alt keys are closest to the space bar.
Otherwise, right click on the Desktop (where there are no programs or icons) and choose Graphics Options > Rotation. Another place to check is right click on the desktop and choose Screen Resolution > Orientation. This is a shortcut to accessing the display properties in the Control Panel. Click Start > Control Panel > Appearance and Personalization > Display > Screen Resolution. For a widescreen monitor, choose Landscape.
I hope this helps.
(The ctrl+alt+arrow key doesn't work on my Win7 desktop but does work on the laptop. The Orientation change from the control panel works on both.)
May 04, 2012 | Acer Computers & Internet
How do I change the display resolution on the control panel ABOVE the maxed out resolution shown so I can use a 17' screen which requires 1280x10xx? When I try to use any 17" monitor, a message comes...
On a 17ins monitor the best resolution is 1024x768 regardless of whether it tells you a different "recommended" display resolution.
Just ignore any warning it gives you and it should work very well with the resolution i've told you, just use the slider to select the 1024x768.
Regards.
Dec 09, 2010 | Acer Aspire AX3300U1322 Athlon II X4...
Adjust the screen/display size for CS-21K10MQ in normal view
This is a hardware fault and is usually related to the flyback transformer and some of the caps that control picture. It needs technical intervention
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Televison & Video
Screen icons and picture too big
What is the OS??
Right click on the desktop and click on "Properties", "seettings" and set screen resolution to at least 1024 X 768 for LCD monitor or 800 X 600 for CRT monitors.
If they are set to those then there may be a prob with video driver.
Need more in depth explaination.
Dec 21, 2009 | Dell OptiPlex 170L PC Desktop
Warning "not optimum settings"
Press F8 as the computer boots up and the Windows Advance Options Menu will be displayed. Then select Safe Mode to boot up the computer.
When Windows finishes booting up, then open Control Panel - select Display - Settings, then change the screen resolution to a lower setting.
Apply and shut down and reboot computer.
Dec 19, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
If we close the screen a little bit it goes bright white. Have to switch off and restart. Also, after doing a power point presentation the display is only opening about 80% of full screen with a black...
In LCD screens is a common problem that after setting a lower resolution than recommended you'll see a black stripe sometimes up and right, right click on any empty spot on your desktop and select properties then go to display options and move the resolution bar to a higher point and click apply also click yes in the warning display and accept.
Regards.
Jun 15, 2009 | ASUS A6Ne Notebook
My Hp PAvilion DV9000 LAptops screen keeps going blank. If I hook it up to and external monitor then it works.
YOUR INTERAL DISPLAY ADAPTOR MAY BE GOING BAD, HAVE U TRIED REINSTALLING THE DRIVER , IF SO ITS UR ADAPTOR OR THE SCREEN ITSELF WHICH IS NOT A BIG PROBLEM REPLACING. THE EASIEST THING TO DO IS ASSUME ITS THE MONITOR. DOES IT DO THIS IMMEDIATELY OR DOES IT TAKE A WHILE. WHEN U HOOK UP THE OTHER MONITOR DO BOTH SCREENS WORK.
Aug 04, 2008 | Computers & Internet
System Does not start
There is a full step-by-step guide to diagnosing this problem on the dell website (actually very helpful). You can find it here (titled Dell? OptiPlex? No Post, No Video for GX100 and GX110): http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=DFB8C72540D611DCACF8FBE14C494B1F&treeid=9F6F166431914C6B9722AA3209A42250&Query=dHJvdWJsZXNob290&SystemID=PLX_PNT_P03_GX110&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
Aug 02, 2007 | Dell OptiPlex GX110 PC Desktop
Computers & Internet Logo
24 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
