Sorry, but it looks as though you have the classic Aeroccino-problem. Nespresso states that leaving the Aeroccino on its base while it is plugged-in to the wall, will cause it to short-circuit (because there is no off-switch on the base, it is continually feeding full power to the frother), and the result is that it makes only warm milk. Replacement is the only solution...I hope you are still under warranty.
Sorry, I neglected to add what others have now responded. 1) Before despairing, do try a fresh, full fat milk---this works best. When I tried older milk, it didn't froth, but there was nothing wrong with the frother. 2) Turning it upside down has to do with water getting into the electrical parts in the base, from washing, etc. Turning it over for 24 hrs doesn't "reset it" but just gives the water a chance to evaporate, if the electrical components have not been affected. 3) A replacement may be necessary if those solutions don't work for you.
Try not so cold and condensed milk!
SOURCE: Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
SOURCE: The Nespresso Aeroccino is frothing, however, as
Have you changed the type of milk? Full fat is best but it should work with semi skimmed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
SOURCE: Need replacement frother part for Nespresso Aeroccino
good to know
the machine is Krups, and therefore you can also get support from them, by calling the number listed on the user manual, or finding contact
from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
All the best
SOURCE: I have nespresso aeroccino machine.
where to purchase the top magnet for the nespresso aeroccino?
Contact the Nespresso Club at 800.562.1465. The replacement frothing/steaming whisk set, item number 13192/6, is currently available for sale at $2.95. .Shipping is flat fee of $6.95
I have a brand new aeroccino. It heats, the frother spins, but I only get a couple of mm of froth and warm milk. I've tried fresh, cold, and room temperature semi-skimmed milk. I've also tried various amounts of milk.
I have a brand new aeroccino. It heats, the frother spins, but no froth (only a mm or so). I've tried cold, cool and room temperature milk, and different volumes, semi-skimmed and full-fat - it makes no difference.
Try a different brand/source for your milk. Trader Joe's (small west coast chain) brand will not froth where Albertson's and Ralph's (large chain) milk works fine. This suggestion came from the Nespresso help-line and was an immediate fix.
flashing light of the aeroccino froth maker
Cannot find my serial number on my new Nespresso that i receive.
Where can i find it?
