Question about Electrolux Refrigerators
Freezer is working fine but the fridge has stoped workin the model number is enb5289x
    Novelist:
  • 116 Answers
I was unable to locate your specific model number but the following rules apply. The usual cause of this is a blockage in the air flow from the freezer to the fridge side.
1. Possible stick baffle valve. This a the vent that allows air to enter at the top of the fridge from the freezer. Check it for obstruction. Alternately if the return vent is blocked the same problem will occur.
2. a defrost problem will cause the air circulation to stop. This can usually be seen by a large amount of frost build up on the back wall of the freezer. This will require a more thorough diagnosis as the circuit contains several parts which could fail.
3. Bad circulation fan. This will not force the air to circulate causing a warm fridge and a cold freezer.
Posted on Jul 28, 2008
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
Tip
I have a samsung fridge freezer model rl41sbtb only 2 years old itt stoped...
If you have a refrigerator or a freezer that is not working like it once did then you are looking to get it working again. The reasons why he unit may not be working properly can be many. One of the reasons may be that the refrigeration unit that is the cooling power of the unit is slowly leaking refrigerant.
If the refrigeration unit is leaking very slowly the loss of charge may be so subtle that you will not notice it till the unit basically stops cooling completely. Then all of a sudden you realize that you have a problem. If this is your problem, you will notice that the compressor is running, the circulating fan(s) will be running, and the condenser fan is running. Everything appears to be perfectly normal, but you are not getting the cooling from the unit that you need.
If you have this situation then there is often not that much that you can do. To recharge the unit you will need to find a technician that is certified to handle refrigerants. The system which is charged and sealed at the factory will have to be tapped and the proper refrigerant added to the unit. Even then you still have a system that is leaking and the fix will only be temporary. Sometimes the leak point will be obvious, other times the leak may be very difficult to find. Most of the time, the leak will be next to impossible to find and repair.
Bottom line here is that you will have to make some hard decisions about the repair of a leaking refrigerator or freezer. If you get refrigerant added to your unit it will be a temporary fix. If you can find the leak and it is repairable, you will have a bill for that repair also. That bill may be more then the unit is worth if it is a basic model or an older model. In many cases the purchase of a new unit may be the best option.
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4326586-new_refrigerator_refrigerator_depth
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
on Jun 07, 2011 | Refrigerators
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
My westinghouse refrigerator has stoped working but my freezer is working fine help. Model Bj513V Serial Number 72656346
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Westinghouse Microwave Ovens
My Frigidaire refrigerator will not cool. The freezer is workin great.
u have a frozen drain in the freezer, thaw the fridge out manualy, for a day or so , then it will work fine for a short while sound like a defrost timer need replacing but make sure theres no ice in the freezer befor starting it up again
Oct 16, 2010 | Frigidaire Refrigerators
I have a ge externa refrigerator that does not cool on top shelves of the fridge or the freezer. it cools at the bottom just not the top. model # is ESS25KSTSS. Fan is workin fine and has freon. If anyone...
If the fan is working fine the next thing to check for is heavy frost on the back wall of the freezer section toward the middle to bottom area. If you have frost there you will need to remove the panel and with ref. off use a hair dryer to defrost the ice from the coils. After the ice is defrosted you will see a defrost heater at the bottom of the evaporator coils. This will be your problem Part number 51x10101 at about 64.00 or less. Hope this helps and good luck. Rick
Mar 09, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
Freezer working fine, but nothing out of refrigerator side!!
can be that the control is not set right,, or the drian line stoped up behind the fridge,, chech the control first to make sure the setting right,, if so pull out and check the line going to bottom make sure water going throught it
Aug 10, 2009 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
165 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
