Question about Sun MySQL
SQL command not working
I went to the mysql prompt and typed ./bin/mysqladmin -u root password;
I get "You have an error in your SQL syntax" and it flags the entire line of code. You said "go to the installation directory of mysql (cd/usr/local/mysql)", is the same as the mysql prompt? 'Also, am I supporsed to be using 'root' as the username?
  • Jill Torgerson Jul 30, 2008
    femster,
    I was attempting to use the mysqldump command to convert my .frm files to a .sql file on my local machine. I was getting an ACCESS 1045 error because the username 'root' had never been associated with my password. I then attempted to create that association using the 'mysqladmin -u username -p password' command that was offered by several people, including you. I kept getting an error. I noticed from the postings that numerous other people were getting the same result. Turns out there shouldn't be spaces between the '-u' and 'username' or the '-p' and password, a simple point that wasn't stated explicitly. When I entered 'mysqladmin -uroot -ppassword', it worked.
  • 71 Answers
Could you give me more info plz
Posted on Jul 30, 2008
Could not connect to MySQL
Hi;
You can start/stop the mysql service on the server by logging into the server as root from the command line interface and run the following command/s.
service mysql stop
service mysql start
service mysql restart
You can also use the following if the above does not work fine.
Fix Toolbox for MySQL
https://www.fixtoolbox.com/repairtoolformysql.html
Jul 07, 2016 | Wolfgang Schmuck MySQL
Tip
4 Methods to Change MS SQL Server Password
Have you ever forgot or lost your MS SQL Server password? Did you reinstall MS SQL Server or change SQL Server Password by some ways at that time? I once forgot my MS SQL Server password and I reinstalled My MS SQL at last as I failed to find some good methods to solve the problem. What annoying and terrible experience it is! In order to avoid reinstalling SQL Server for a second time due to the same reason, so I collect some methods to change SQL Server password for sa account.
Method 1: Use Command Prompt to Change SQL Server Password
Step 1. Open a command prompt (Start -> Run -> cmd)
Step 2. Type the follow commands, and press Enter after each line:
Osql –S yourservername –E
1> EXEC sp_password NULL, ’yourpassword’, ’sa’
2> GO
The yourservername is the name of your server, yourpassword is the new sql sa password.
The command line 1> also can be changed to other command, the model is EXEC sp_password ‘oldpassword’, ‘newpassword’, ‘sqlaccount’.
Method 2: Use the Query Windows in Management Studio to Change MS SQL Server Password
Step 1. Open SQL Server Management Studio
Step 2. Open a new query
Step 3. Type the follow commands and excute:
GO
ALTER LOGIN [sa] WITH DEFAULT_DATABASE=[master]
GO
USE [master]
GO
ALTER LOGIN [sa] WITH PASSWORD=N'NewPassword' MUST_CHANGE
GO
The NewPassword is set for your SQL Server sa account.
Method 3: Change SQLServer Password by Windows Authentication
If Builtin/Administrator is present in SQL Server, you can login with an ID which is member of Administrators group and change sa password in SQL Server. Just do as follows:
1. Login into SQL server using Windows Authentication.
2. In Object Explorer, open Security folder, open Logins folder. Right Click on sa account and go to Properties.
3. Type a new SQL sa password, and confirm it. Click OK to finish.
After restarting SQL Server and all its servers, you can log into SQL Server by sa login with new SQL sa password.
Method 4: Change MS SQL Server Password with Third Party Software
In addition to the methods above, you can aslo choose some SQL Server password recovery tool to change SQL Server password. MS SQL Server Password Unlocker is one of the good MS SQL passwrod reset tools which can help you change SQL Server password in a few seconds. It allows you to chage MS SQL password on SQL Server and Express 2000/2005/2008.
Following is a guide for you to change MS SQL password with MS SQL Server Password Unlocker.
Step 1.Download and install MS SQL Server Password Unlocker.
Step 2. Run MS SQL Server Password Unlocker, click Open, import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with it.
Well, the four solutions are the easy-to-use MS SQL Server Password Reset ways.
on Aug 10, 2010 | Computers & Internet
How to restore MySQL database Windows tool?
You can restore corrupt and delete SQL database file in few steps for MySQL Restore Toolbox. With this software you can also recover triggers, keys, indexes and table. Software support multiple MDF file recovery option. Software is supported by all Windows operating system. Get more ideas and download free trial version from -http://www.filerepairforum.com/forum/databases/databases-aa/mysql/1162-dump-mysql-database-file-is-error
May 29, 2015 | Sun MySQL
Why mysql blackscreen dissapear when press enter button
this is normal for mysql server. It's simply wanting you to set the administrator password. the black box appears, you type your password, the black box closes.
This means the password is now set to what you typed in the black box (command prompt box)
Aug 07, 2014 | Microsoft Windows 7 Ultimate for PC
How to move one mysql database to another machine
After logging into MySQL via command prompt, use the below commands.
Backup :
databasename > dumpfile.sql
Restore :
source dumpfile.sql
If you have an IDE like HeidiSQL or SQL Yog, they can make tasks easier through visual interfaces.
Mar 12, 2013 | Computers & Internet
Cannot connect root@localhost error 1045
This is an access denied error. If you have specified a root password during install, you must supply it when you connect, e.g.:
mysql -p
will prompt you for the password.
Aug 23, 2011 | Sun MySQL
MYSQL Access denied
Hi Buddy,
Try this option....
mysql -u root -p
mysql will then ask you for the password give the proper password.
For changing mysql root password
mysqladmin -u root -p password <<newpwd>>
then mysql ask you to give password this is the old password and now the new password for the root will be newankush.
Sep 10, 2008 | Sun MySQL
Table Repair MySQL
MySQL offers Check Table syntax that checks a table or tables for errors. It works for several storage engines like MyISAM, InnoDB, & Archive. If you run this syntax then you can the cause of problem & reported tables.
If Check Table finds errors then you can repair reported tables by Repair MySQL Table syntax.
Aug 06, 2008 | Sun MySQL
MySQL Error Messeage
When you install MySQL for the first time, no password is set for root user.
Move to the installation directory of mysql (cd/usr/local/mysql) Set the password for user, using the following command -
./bin/mysqladmin -u <username> password
Enter your password. Then you can connect to the mysql client as
./bin/mysql -u <username> -p <password>
Jul 27, 2008 | Sun MySQL
Sun MySQL Logo
142 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
Tape-Techie
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
