With the Panasonic TH-37PE30 Tv, When trying to use the AV3 connection the sound is playing however the picture does it. on the top right hand of the screen it says "No Signal". I have tried it with two separate connection leads. Could it be to do with the "yellow" video connection on the tv, or is there a simple solution
I got it sorted. It was to do with the yellow cable, n video signal.
Posted on Jul 29, 2008
Remove the floor stand from TH-37PE30 Panasonic tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Panasonic Televison & Video
How do I remove tv from stand Panasonic th-37pe30 tv
Nov 28, 2014 | Panasonic TH-37PE30 37 in. Plasma...
I have a 42 inch panasonic viera th-p42g10a. i have dvd connected to av1, foxtel to av2, av3 is vacant. I have lost volume to both dvd and foxtel connections, yet i still have volume when watching normal...
This is a problem with your components. You can have the components replaced with a new set which may be expensive, or live to learn using av3 only with a switch system.
Mar 03, 2011 | Panasonic VIERA TH-42PX80E 42 in. Plasma...
In my tv i have connected set top box to av3 i can see the pictures but no volume. i have have a dvd payer connected to HDMI1 and it is working ok. it used to work ok but some how there is no volume...
When it is certain that the volume on the TV functions properly try to ensure also that the set top box also produces volume. This you can do by connecting the set top box directly to your DVD auxillary channel. If any volume comes out of that then you can be sure the fault is from your connection. But if on the other hand the the box does not produce any volume then the set top box is faulty. Therefore you have to send it back to your supplier.
Hope this solution has been helpful?
Sep 26, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
CAN TH-37PE30 37IN BE CONVERTED TO HD
For a short answer - no.
It requires a new tuner, cards, and larger power supply.
The cost of conversion far outweigh the price of a new unit.
Thanks fo rusing FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 30, 2009 | Panasonic TH-37PE30 37 in. Plasma...
Circuitry does not support 720p or 1080i. NO!
Convert PANASONIC PH-42 PWB6 IN TV
buy a tv tuner, or hook up a dvb-t tuner to it
Aug 17, 2009 | Panasonic TH-37PE30 37 in. Plasma...
I have a Panasonic TH-50PZ700U, with a green 2'' vertical line in the upper right hand corner. The green line is there regardless of input and is constant. Around the line can have lighter lines at times...
It is the buffer X board. They are loacted at the botton of the set. Replace the one connected to the display panel directly in line with the lines in your picture.
May 08, 2009 | Panasonic Televison & Video
PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Jan 16, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
