Question about Kenmore 54701 Dehumidifier
Slight beep but no action/can't get the back off
Two part question: Why won't it work and how do I get the back off?
It worked fine last year but after sitting approximately 8 months it doesn't turn on anymore. When I plug it in it makes a soft beep but doesn't do anything. I tried to take the back off (removing the screws) but the back wont come off - it's stuck. Am I missing something?
  • Anonymous Aug 04, 2008
    i cannot get the back off of kenmore model 54701, fan blade is hitting on something
I had the same problem (minus the cover issue) . To get the cover off, take off all visible screws. Slide a small screwdriver into the space between the back and the side cover. You will see a slight opening where the tabs fit in, you will need to carefully pry the tabs out. However, most likely your problem is with the front panel. You take the front panel off much the same way. 2 screws are concealed by the bucket. I had the same beep no display, thought it was the main pcb, which I ordered and installed. That did not fix it. I cleaned the display pcb, and jiggled the buttons, that seemed to fix it. I think the button to increase the humidity was stuck closed, as I could replicate the problem by holding that button down and then plugging in the dehumidifier. I would start by cleaning or replacing the front panel pcb, which is about $14.
Posted on Dec 05, 2008
Hello, why does my dehumidifier goes on and off every 4 minutes, last year was working fine, started the machine last week ans now it goes on and off, thanks
Serge,
Most dehumidifiers work on a thermostat, and yours probably got turned down. You might look on the top and see if there are any knobs and try to adjust it that way.
May 26, 2015 | Dehumidifiers
When I plug my LG dehumidfiyer Model LHD659EBL I hear a small beep and nothing happens. I can not turn it on or get a light on the panel to even light. This unit is only a few years old and it worked fine...
Remove the water collection bucket and reinstall it. Make sure the bucket fits "squarely" in the holder from top to bottom. The bottom should not tilt down at the bottom, when it's properly installed.
While you have the bucket out, look in the top of the bucket for a float valve. If it has one, it may be stuck in the UP position. Juggle the float arm to get it to return to the DOWN Position and reinstall the bucket as described above.
Either of the tings mentioned above, will cause the unit to not turn ON.
Hope this helped you and thanks for choosing FixYa.
Jul 26, 2011 | Dehumidifiers
Hello, I have a Whirlpool dehumidifier Model# AD25USV (recall adjustment already complete) I have never had any technical problems or damages to the unit, and it has worked great, until...
Hello Shane
Mine won't beep at all. But try this trick I watched the guy do when he came to service mine for the recall they had and push Humid button fan button and power button first hold the first two then push the power button and hold all three for awhile. What this did for him was verify all systems working all the lights came one in sequence.
I do this to mine and will beep twice and nothing else. I've taken mine apart to check the fuse and it's still good so there must be a component that is not working.
On the back of your unit you will find a 800 number which will get you in touch with Trans Global Service which serviced it for the recall.
George
Jul 07, 2011 | Whirlpool Dehumidifiers
My kenmore 580.54501 dehumidifier runs and runs, but does not dehumidifer. It worked fine for 1.5 years. we looked through the troubleshooting list... alas nothing seems to work. could it be that...
ME TOO...I've bought TWO of these POS's in the last 4 years, and they both broke down in just less than TWO years...and Sears will do NOTHING for me!!!!
Nov 19, 2010 | Kenmore 54501 Dehumidifier
Dry function will not work
There are Five Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is locked up
Aug 07, 2009 | Danby DDR583R Dehumidifier
Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
Jul 09, 2009 | LG LHD45EL Dehumidifier
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Jun 10, 2009 | Haier HDN655E Dehumidifier
Electrohome dehumidifier stopped working
I have no experience of your particular machine but I have some experience of my Wood's DS-15, another fine machine of the compressor type that is built to last. They should be rather similar in design.
My first thought when I read your problem description is that you have a severe buildup of dust inside the machine. On the Wood's, you loosen the front grill and behind it you will see the fan, behind the fan is the condenser pack, and then you get to the evaporator coils that are visible from the back of the machine.
Maybe the configuration is slightly different on your machine but they are built very simple these machines, easy to see what they need in order to work as designed and you already know the most central and expensive parts seem ok.
I had some problems with low efficiency on the unit after six years daily service in a laundry room for drying clothes, took it apart and couldn't believe the amount of dust that was packed into the fine fins of the condenser on its back side! Also extremely much dust on most components like the fan.
I just took it outside and blew it clean from the front side with compressed air, problem solved and machine performance went back up to where it was when new!
I would imagine after a few more years of dust buildup inside, at one point or another the dust will reach the fan and prevent it from spinning. It is also possible of course that the fan motor is shot but I'd start with a really good cleaning.
If that doesn't help I'd continue with the multimeter see if the humidistat gives power to the fan and compressor when it should, if the fan actually spins when powered, if the switches work. It should be quite easy to track down the reason the fan doesn't spin, IMO. I believe you can buy replacement humidistats and motors if they turn out to be faulty.
May 26, 2009 | Dehumidifiers
Leak
Mine did this last year. I took the housing off of the left side and found a clear plastic tube had popped off the fitting, I put it back on and it worked fine. The tube was toward the lower front of the unit.
Jun 01, 2008 | DeLonghi DE400 Dehumidifier
No lights, won't turn on
I suggest checking the fuse on the circuit board.
Oct 19, 2007 | Kenmore 54701 Dehumidifier
Kenmore 54701 Dehumidifier Logo
284 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
