Question about Pioneer SD-643HD5 64" Rear Projection Television
Power problem when you turn on the main power button on... the red standby comes on and the green power button comes on at the same time ...but the green button go's off and no picture is there. ???? I had moved it away from the wall to look at it ... and after a couple of times trying... it came back on ... when i move it back ... it happened again.
  • Anonymous Sep 04, 2008
    took back of tv off and found a blown fuse thought my problems were over but turned my tv on and nothing happened checked the fuse and it was blown again fuse location is 303 it is a 4amp-125v
  • mlittlejohn Nov 11, 2008
    I push the main power button on and the red standby light turns on. I push the smaller power button and nothing happens. I can hear the tv click as if it is turning on, but nothing comes up on the screen. It worked fine 12 hours ago. What should I do??
  • 27 Answers
Its the Transformer a capasitor and 3 resistor's..OK cost 355.00 I will give you 150 for the TV and i will pay to get it fixed ..Its not really worth it to hold on to it ...150.00 and 355.00 will that work for you... I will be buying it for 505.00 is that enough.
I had the same prob ...so tats what I did and baught a new one .
I CAN GET YOU ANY TV AT 1/2 OFF ANY WAY ...radricktip@gmail let me know what size and the most you have to spend on it...Is that ok with you??
Posted on Nov 21, 2008
I just had this same problem. I replaced the 303 fuse and it works like a charm again.
Posted on Oct 12, 2008
Sylvania plasma tv will not turn on
power supply board has defective components,check for swollen capacitors and replace them,if problems still not solve email me at rspoliah@gmail.com .for further instructions
Aug 14, 2014 | Sylvania 6842THG 42 in. Plasma HDTV
Does not power on
ok on pioneer most of the time it is because of bad connections all over the main power supply board solder these and see what happens like i said most of the times it starts with bad connections.
Nov 18, 2007 | Pioneer PRO-119 60" Rear Projection...
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
My dynex tv will not come on seems to be stuck in standby mode.
It sounds like the main power supply is trying to startup but failed because there is short circuits or the main power supply is bad. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Dynex DX-LCD37 TV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Oct 09, 2007 | Sylvania 6626LCT 26 in. LCD Television
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Pioneer SD-643HD5 64" Rear Projection Television Logo
101 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
