LCD Monitor
Ihave a new LCD Monitor .What is the best way to clean the screen. Is WindTex OK K???
  • berbob Jul 30, 2008
    Thanks ozserviceman.
    Bob
    Problem Solver:
  • 14 Answers
Don't use any chemical cleaners. First try just a damp cloth. If no good the next best is iso-propyl alcohol on a lint free cloth, but use sparingly.
Posted on Jul 30, 2008
I HAVE DELL LCD TV SCREEN 2007FPB SUDDENLY IT DOES NOT WORK WHEN CONNECTEC TO POWER SUPPLY, PREVIOUSLY IS GOOD WHAT IS THE PROBLEM & HOW MUCH MONEY NEED
First check your monitor light is blinking or not. If it is then--
Check your monitor cable which is connected your CPU. If it is ok then
Open your CPU and unplug *********** board power cable and re-install it.
And also remove RAM and clean with a brush softly and re-install it.
Best of Luck
May 13, 2011 | Dell E173FP 17" LCD Monitor
Tip
Tricks Clean an LCD Screen
Enhance. Turn off your LCD monitor can be spots or areas that need to be cleaned more observable.Dust it off. Then use the microfiber cloth and wipe carefully collected the dirt off the LCD display.Use a suitable cleaning liquid. You can buy a cleaning kit, which are usually manufactured specifically to keep your LCD screens in the best conditions. There are LCD natural cleaning products and take into account.Work with the correct tissue. When cleaning LCD screens, use a good old cotton shirt or a handkerchief or buy special wipes to thoroughly clean the LCD screen. Spray cleaning solution on the cloth and clean with gentle circular motions. Let dry. Make sure your monitor is completely dry before using again.
on Feb 08, 2011 | Computers & Internet
Plugged in a new 23 inch LG LCD Monitor and cannot get picture
In additio to the fine help given by Mister.
If you have a DVI output on your computer get the cable for that and this will greatly increase the quality of your display.
Your graphics card should be able to autodetect a DVI monitor and suggest the best display type.
Sep 16, 2009 | Computers & Internet
Cleaning lcd monitor screen
use any soft clothe with liitle bit wet and wipe on screen.and leave it for 10 minutes .
Sep 08, 2009 | Computers & Internet
Ihave a HP DV6000 laptop with a 15'' screen and there is a horizontial line all the way across the middle of it what is my problem. Thanks
To determine if you have a provlem with the LCD screen or the video card, connect an external monitor to the laptop's video port and power up the monitor first and then the laptop. The video will divert automatically to the external monitor. If you get a normal Windows image on the monitor then the fault is with the LCD screen, if not then the fault is a faulty video card.
Get back to me with the results of this test.
Jun 28, 2009 | HP Computers & Internet
Ihave an acer 9410Z laptop the backlight won't
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Mar 11, 2009 | Acer Aspire 3000 Notebook
What is the best method for cleanig a flatron
Take a clean cloth and spray some windex on the cloth and then wipe down the screen and it should come nice and clean. Never spray it directly on the screen cause if the liquid goes down inside of the screen then it could damage it.
Mar 01, 2009 | LG 22" FLATRON LCD Monitor
Cleaning
Buy an cleaning kit with cleaning solution, and clean the display very carefully. If you apply too muck pressure you can damage the LCD display.
See also:
How to Properly Clean your LCD Screen
How to Clean an LCD Screen
How To Clean A Flat Screen Monitor
Dec 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dell E173FP: Screen Washes out
not a happy machine...
1. Check in systems manager, device manager, to see that the monitor is clean, with no ? mark or ! point.
2. Reinstall drivers..
3. check all connections to monitor for fit. Unplug and check the connectors for grit or crud.
4. Get a new monitor.
Got backup?
Feb 10, 2008 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
444 people viewed this question
David Payne
David Payne
