Wireless Zero Configuration (WZC) was
introduced with Windows XP, it is also known as WLAN AutoConfig in
Windows 7 and Vista. It is is a wireless connection management utility
which dynamically selects a wireless network to connect to based on a
user's preferences and various default settings. or most users the
Windows Wireless Zero Utility is all that is needed to manage your
wireless connections.
You can configure WZC as follows:
Type services.msc in "run" and enter.
Select wireless zero configuration from the list which appears in the next window.
Double click on that option , and choose to Start or Stop the Wireless Zero service.
Here are steps to use Wireless Zero Configuration/WLAN AutoConfig in Windows 7:
Click the Windows logo button
Type
services in the Start Menu's Search box and press Enter. Scroll to the
bottom of the list and locate WLAN AutoConfig'. Double-click WLAN
AutoConfig to open its Properties window.
Click the General tab
of WLAN AutoConfig service. Click the Startup type drop-down menu and
click Automatic to have the service started automatically when the
operating system loads. Click the Start button. Click Apply and then OK.
Close the Services console window.
button. Type cmd in the Search box and press Enter. In the Command
Prompt window, type netsh wlan show settings and press Enter. Look at
the last line of the Wireless LAN Settings entry to see if the message
Auto configuration logic is enabled on interface or Auto configuration
logic is disabled on interface appears. If the entry notes that it is
disabled, type, set autoconfig enabled=yes interface=Interface Name and
press Enter. Close the Command Prompt window.
check if your router is broadcasting SSID if so, then check if your laptop wireless is ON. check the services if it is started. To check if is started. follow the steps below for Windows Vista/XP/7 1. press and hold the windows logo on your keyboard then press letter R. 2. type on the run field services.msc then click OK. 3. From the services page look for WIRELESS ZERO CONFIGURATION or WLAN (alphabetically arranged). 4. Double click WIRELESS ZERO CONFIGURATION or WLAN then on the service status select AUTOMATIC 5. ON the service type click start 6. From the system tray look for wiless icon(right click and select view wireless network or connect to a network) = it should show couple of SSID to where you can connect. 7. Choose your own SSID 8. When Passphrase key box appeared type your wireless password. 9. Once its connected open a web browser and access website (example www.yahoo.com)
Your problem may appear from a not properly enabled WLAN card. Make sure the Wi-Fi swithc is in ON position and on your laptop keyboard try the FN+F8 combination to have displayed the wireless card status. The WLAN card has to be ENABLED to be able to connect to the Internet. The combination done will make appear on your display a window with some options available; choose that option that enables your wireless card. Also check in your computer's DEVICE MANAGER if your WLAN card is working properly. To do so follow these simple steps: 1. START and click on SYSTEM; 2. in SYSTEM option click on DEVICE MANAGER; 3. on DEVICE MANAGER option go at NETWORK ADAPTERS and see if there your wireless card is indicated and it shows that it is working PROPERLY; 4. if an UNKNOWN DEVICE is indicated then try to find the right driver for you notebook model and WLAN card model; 5. install the driver then REBOOT and recheck in DEVICE MANAGER if your WLAN card is displayed properly this time.
Have you installed any new software? Or any program updates. To me it sounds as though your drivers have become corrupted. What you need to do is to go to the HP support website and re-download the correct drivers for your HP model and Operating System. When you update the drivers reboot and check to see it you're good to go...All the best
Click Start button in RUN prompt, type "services.msc" without the quotes. scroll down till you get :WLAN Autoconfig" Double click on the "WLAN Autoconfig"
Click on Start button and set the startup type to "Automatic"
Sounds like the device driver to the wireless card is corrupt. Click on start>right click on My Computer>Properties>Hardware tab then Device manager. Click on the "+" sign next to your wireless Network adapter. Then right-click on your network adapter, click on Update driver. The system will automatically look for the new driver and download it. If there is no new driver then go to the manufactureres website. All of the drivers are there. Find your computer and download the driver.
Don't forget to rate this solution before you log off.
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Showing " Check operator service"
when call is made
