Question about HP PSC 2110 All-In-One InkJet Printer
Printer Cartridges wont slide to center position
I have a hp psc 2110 all-in-one printer and i need to change the cartridge. When I lift the top to do so the cartridges do not slide to the center so I can change them, instrad it just stays in the far right coener completely out of reach. My question to you is this, HOW DO I MAKE IT SLIDE TO THE CENTER POSITION??? It's driving me insane. PLEASE help me.
  • Anonymous Aug 20, 2008
    I have the same problem WHAT DO I DO PLEASE HELP
    Problem Solver:
  • 4 Answers
This also happened to my 2110 and unplugging it for several minutes caused it to initialize when powered up again. I then copied a page and it functioned normally after that.
Posted on Aug 19, 2008
I cannot access the exsisting print cartridges to replace them on my hp psc 500 printer
Hi
Please note that the print cartridges can only be accessed when the printer is on.
  • Turn the printer on.
  • To access the cartridges,open the cartridge access door on the front of the printer and right above the paper output tray.
  • The cartridge carriage moves to the center so you can access it.
  • On the top of each cartridge is a latch,lift it.
  • You need to grasp the handle at the top of the cartridge pull forward and lift it up to remove.
Hope it helps.
Feb 22, 2012 | HP PSC 500 All-In-One Printer
How to clean the printer heads. Printer has not been used for years.
You shouldn't need to HP printer cartridges come with a new print head. Just put in new cartridges.
Aug 31, 2011 | HP PSC 2110 All-In-One InkJet Printer
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Put in new cart. in 2110 psc it says to remove and check cart.won't accept and operate
OPEN THE TOP UNIT.remove the cartridges .you can see metal contacts in the printer carrage unit.clean the contact with soft tissue cloth.
Oct 24, 2009 | HP PSC 2110 Color Printer
Im trying to remove the cartridges ffom my printer but they are not budging ..what do i do ??
This is the way to properly remove the cartridges:
Step 1: Open top of printer
Step 2: Lift up the flap on top of the cartridges by first pushing down, then pulling out, then pushing up
Step 3: Slightly push up cartridge and pull out
Step 4: You now have the cartridge out
I hope this helped! :]
Dec 02, 2008 | HP PSC 2110 All-In-One InkJet Printer
Cant get to the ink cartridges
You must open up the printer. The lift point is in the front between the paper output and glass scanning surface. You should see an indent there . When you lift it up (it does weigh a slight bit), the printer heads should move to the access position. There is a lever on top of each cartridge to unlock it front the sliding carriage.
Caution - do not close the printer until you lower the cartridge levers. Why? - The carriage will want to slide to the right (home position) and the levers will stop that. It makes quite the racket and can cause part damage.
Hope that helps!
Nov 29, 2008 | HP PSC 750xi All-In-One InkJet Printer
Hp psc 2110xi all-in-one
In the below document read the section titled solution5:Remove and reinsert the ink cartridges
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=uk&docname=c00042573
Sep 13, 2008 | HP PSC 2110 Color Printer
It says "remove and check cartridge"
Did you put in the same model number cartridges ?
If it is ok Reinstall the printer driver
Jul 06, 2008 | HP PSC 2110 Color Printer
Hp psc 2110
there are 2 catridges. You need to lift the top half of the machine (the rlease is wehre you put the paper in), the catridges will come to the middle position, then simply lift the clip and remove the cartridge
May 03, 2008 | HP PSC 2110 All-In-One InkJet Printer
HP PSC 2110 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
