Question about Sony Ericsson K800i Cellular Phone
Not working my phone is not switching on
  • 1 more comment
  • Anonymous Jul 29, 2008
    my phone is not switching on....the battery is charged....the connectors are clean...when is pressed IR flashes on side of phone....help.
  • Michael B
    Michael B Jul 29, 2008
    evening chaps, I have come across your bulletin whilst researching the very problem thomas has described .... handset turned off as I was about to open text message, would not turn back on, charged battery no good, swapped battery no good, IR light comes on when on/off pressed but nada after that, dead as a proverbial flightless bird. My favourite phone by far to date don't want to lose it, espegially don't want to lose the last 6 months worth of phone numbers.
    Any sugestions would be most gratefully accepted, cheers Welshwind
  • richyjith Mar 29, 2009
    before battery is fully charged
    Genius:
  • 1,011 Answers
Dear,
check ur battery. is it fully charged or if charged then try after changing it.
if nothing happened after checking it then it may be the lcd or board fault.
regards,
Posted on Jul 28, 2008
Phone MT65xx is not switching on what to do... charging already full.. it was working suddenly everything gone now no display on phone
Sounds like hardware problem. Maybe screen dead and needs to be changed. I would take it to a service centre to get it tested...
Mar 09, 2013 | Apple MD379LL iPhone 4S 32GB Sprint Mobile...
Tip
This is the tip if the phone gets into water
if the phone gets into water then dont switch on the phone remove the battery and take a hair drier , dry the handset so that the water particles inside get evaporated and after that put the battery and switch on the phone ...
the phone will surely work as normal ...
if you try to switch on before drying then short circuit may occur and you may face some problems like displaying not working etc etc ..
so if the phone gets water damaged then first thing you must do is to dry completely before switching it on ....
rate my tip ....
regards
-Dileep
on Dec 26, 2008 | Nokia N95 Cellular Phone
My nokia6500s-1 on switch not working how can I on it?
There is no other way to switch on you Nokia phone other than using the ON switch.
Get the switch repaired and then you will be able to switch on your Nokia Phone.
Mar 30, 2011 | Nokia 6500 Slide Cellular Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Samsung D840
You need to have the sub-board replaced on the phone to have it working again so take it to a mobile service center to have it working.
Jun 29, 2008 | Samsung D840 Cellular Phone
Cel phone (Rogers)
Try tehse steps
1. Switch off and switch it back on , leave it switched on for 2-3 hrs and then check
2. Switch off and take out battery , when battery is out , press power on button for 30 secs and then out battery back again and switch on the mobile. This process is known as releasing flee power.
3. If still does not work, Then try to do a reset for the phone .
4. If still does not work , try to send a text message or a SMS and check whether it works or not.
5. If still does not work , then contact the people whom u pay for the phone bills and check with them whether there is any proble from their end or not.
6. If still problem no resolved, check whether accidently you have barred all outgoings from ur phone and do check the network selceted mode should be automatic , by mistake no other network should be selected
7. Check whether phone is range of signals and signal strength is excellent.
8. If still does not work then contact , the phone manufacturer, phone antenna might not be working and is unable to receive any signals....
Feb 21, 2008 | Cell Phones
Razor v3i dolche&gabbana
Try tehse steps
BEST OF LUCK
Feb 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Touch Screen Not Working
When i switch on the phone,it works normally,but as soon as i touch the screen the phone freezes... i have to remove the battery to switch it off..
Feb 06, 2008 | Motorola Mobility A768i Cellular Phone
My phone does'nt work
Be sure both the line cord and the handset cord are plugged in. If they are, plug a working phone into the dead phone's modular wall outlet. If it works, assume the problem is with the dead telephone. Try plugging the dead phone into a working outlet. If it works there, its cord or modular plug may be making a poor connection with the first modular receptacle. Switch cords with the working phone and try again. If it works, replace the cord. If it doesn't work with a good cord, plugged into a working outlet, the phone is probably defective. Further isolate the problem by substituting the handset from a working phone. If it works, repair or replace the dead phone's receiver. If it doesn't, repair or replace the entire phone. Be sure the switch hook isn't stuck down or jammed.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Sony Ericsson K800i Cellular Phone Logo
60 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
