Speakers. Only get sound from one off the three speakers. All wiring seems to be connected properly. Tested speakers by switching with one that works, and they all work. Also large speaker connected properly, but no sound?
Contacted a local service dealer
Posted on Jul 29, 2008
Hook up radio to jeep cherokee
buy a 12 volt lamp tester (like a screw driver)check the wires when car ignition switch is turned on ,connect the wire side of tester to metal ground of ur car which supposed to be negative and other side of tested pin to the wires jack of ur car which is for radio connection previously,find out 2 connection points which are positive terminals one lights when igni switch is turned on the other one is permanent power terminal.now there are three wires of ur new radio one is black which should be connected to ground or metal body of ur car negative terminla and yellow connected to permanet power terminal and red one should be connected to power turned on with the swith which is called switched power
.now try to find out other four groups of terminal two for front speaker two for rear speaker each speaker has two wires ,can find out the connections by connecting a dry battery cell to the wires to identify which wires of speakers sound when battery is connected ,front pair of wires is for front left grey pair is for right front green pair of wires of ur new stereo is for left rear speaker and purple or blue pair is for right rear speaker
.these colors are globally known .the wires of speakers must not mixed with each other
black is for ground negative red is witched power and yellow for permanent power.
donot use long screws to fit ur new radio .Best of luck
Nov 18, 2013 | JVC KD-S5050 CD Player
My pioneer deh-p840mp powers on and flips open, and seems to function fine with the exception of no sound going to all my door speakers and the bass to my subwoofers is a far sounding muffle even as I turn...
Un hook all your speakers that the deck is powering and hook them up one by one sounds like u have a shorted speaker or wire and the unit is going into protection.The best way to chk the speakers and wires is with an ohm meter . Check each speaker wire to ground and across the speaker and see iof you have any shorts. The next step woulk be to remove the unit and have it bench tested.
Jul 30, 2010 | Pioneer DEH-P840MP CD Player
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
Putting Speakers in Door Dont Know how to wire them correctly
Wiring speakers with reverse polarity doesnt have adverse effects. It cant give distorted sound. Seems like the wiring from the head unit to the speaker might be at fault. For testing purposes, connect the speaker directly to the head unit, bypassing, the car wiring. If the sound comes out alright, you have to replace the car wiring. If it is still distorted, speaker might be at fault. Try with a different speaker.
Oct 20, 2009 | Pioneer TS-G1642R Car Speaker
Sony STR DE845: rear speakers not working, three fronts are OK.
The rear amp is malfunctioning (duh). Take it to a tech for a real diagnosis.
Sep 05, 2009 | Sony STR-DE845 Receiver
Sony speakers do not switch on
I think ur sound driver not properly installed plz reinstall again properly .
May 26, 2009 | Sony SRS-D2100 Computer Speakers
Installing 4 after market speakers in my Ford F-350. POS/NEG post
this is actually a quotation from a site on the net as i've wondered about it to
"Speaker wire has a mark or strip on one of the conductors this is to indicate polarity of the wire. When installing speakers to the output of an amplifier you need to observe the proper polarity. This is particularly important when installing a surround sound system with front and rear speakers. If the polarity is not followed then the results will be poor balance of sound and even cancellation of some frequencies."
Robert
Jan 21, 2009 | 1994 Ford Mustang
Broken output signal
sounds like you have some loose speaker wires somewhere, or touching wires. check to make sure ALL wire connections are solid, and sealed with tape or a connecter. if any wire is touching any metal on the car or another wire it will cause interference
Jan 05, 2009 | Sony XM-1002HX Car Audio Amplifier
No Sound
Three things to look for for the no sound problem:
1) Make sure the pre-out main-in couplers have jumper wires in them
2) Make sure the mute is not engaged
3) make sure the speakers wires are inserted properly. you need to unthread the five-way binding posts before inserting the wire between the post nut and receiver.
Aug 31, 2007 | Yamaha RX-V2090 Receiver
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
