Question about Toshiba Satellite A135-S2276 Notebook
Toshiba I'm having trouble resting me bios passwork. As soon as I push the power button is prompts me for a passwork and i don't know it. HELP
Hi there. There should be a jumper on the motherboard to clear your cmos password. If you have the book for your laptop with info on the motherboard it should show you the location.
Take the jumper off pin 1&2, move it to pins 2&3 for a moment, then put it back. CMOS p/word will be cleared.
Posted on Jul 29, 2008
Need to access the menu
Know what the ->enter BIOS Setup key is?
It's on the bottom of the computer manufacturer logo screen.
Got it?
Now press the CTRL and ALT and DELete keys at the same time.
Restarts the computer.
JUST AS SOON AS IT STARTS, start tapping on the enter BIOS Setup key.
Tap in 2 seconds intervals.
If you hear beeps ignore it. These are Stuck Key Error Code beeps, and it is you that is making them.
Still No?
Turn the computer off by holding the Power On button in, for 10 seconds.
WAIT 20 seconds, then press the Power On button.
AS SOON AS YOU PRESS the Power On button, start tapping on the enter BIOS Setup key. The rest is above.
Regards,
joecoolsvette
[The time period to enter BIOS Setup goes by F-A-S-T!
As soon as you see the computer manufacturer 'splash screen', (Logo screen), it may be TOO late. The above method makes sure you get in BIOS Setup ]
Nov 21, 2012 | Computers & Internet
How to reset bios password on toshiba portege m200 2001
Open CPU Cabinet's case and look for button cell of coin size on the main motherboard(circuit board) and push the pin with holding the button cell, the cell will come out. This will power off the BIOS memory and the BIOS will reset.
Oct 18, 2012 | Toshiba Computers & Internet
System type: dc 7700 hp desktop. Soon as I switch on the power from the wall sucket and the UPS,the computer will just turn on automatically without waiting for me to push the power on button. I know this...
Don't worry about it, it is just a setting in the BIOS which causes the system to return to the last state before power was removed. It will not cause your system any damage.
Jan 28, 2012 | HP Computers & Internet
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
I have laptop toshiba sat a100-467 and i forgot my bios password is there any solution so that i can bypass the bios passwork or remove
For you to be able to remove the BIOS password, you will need to reseat the CMOS battery on the Motherboard, that will reset the BIOS password as well.
Hope this will help... Please rate...
Jan 20, 2011 | Computers & Internet
Toshiba
your bios have a password setting, it would be inappropriate to tell you how to do this because we don't know if you own this pc
Aug 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba
There is a jumper on motherboard, or you can remove the motherboard coin battery for one minutes.
Both ways to reste bios involve taking apart the laptop to access the motherboard.
You will need to disconnect power adaptor and remove laptop battery before disassembling the laptop.
If you do not have experience in disassembling laptops I suggest to having it done at a repair shop.
Jul 28, 2008 | Toshiba Satellite A135-S2276 Notebook
Reset
It will be on the main board of laptop. You need to open the base and keyboard of laptop. Careful
May 21, 2008 | Toshiba Satellite A215-S5822 Laptop
Bios password
Is it the BIOS password you're troubles with or is it the Windows password?
Nov 27, 2007 | Acer Aspire 5610-4648 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
