Question about Lexmark X75 All-In-One InkJet Printer
Printing thanks 4 the answer but how do I get to the feed wheels ? I dont know anything about the printer I just press the buttons sorry,
  • 81 Answers
Try cleaning the rollers really well first. I checked my usual sources and could not find any rollers. At this point, I suggest that you find someone locally to help you out. Sorry I cant be of more assistance.
Posted on Jul 28, 2008
How do I perform a test print on a Tec B-572 printer?
I'm sorry for late answer.
Just turn it off, Hold feed button for 5 secs while you turn it on again
Jan 31, 2013 | Toshiba TEC B-572 Printer
My HP Deskjet 6540 doesn't print the test page or anything else.
How do I print a test page without the printer being hooked up to a printer ?
Feb 08, 2011 | HP DeskJet 6540 InkJet Printer
Label size formatting I have 4 x 6 labels and each
This can depend upon several things -
Does the printer feed the tickets through normally when pressing the feed button?
If it does not, I suggest the ticket has the length and width defined incorrectley.
The othe rissue maybe in the printer detecting the gap bewteen the tickets. To solve this issue , more information is necessary,
can you print a ticket to a file and post it?
Sorry I can`t be of more help
Aug 30, 2010 | Toshiba TEC B-472 Thermal Label Printer
I'm trying to print a label but it is feeding to the next label.
Sorry , but there is insufficient information to solve this issue.
After skipping one label, does it print correctley?
If you press the feed button, does the printer feed through to the next ticket, or does it print correctley?
May 20, 2010 | Toshiba TEC B-472 Thermal Label Printer
The feed switch on my Canon Printer MX700 keeps reverting to the rear tray, so I cannot print out anything on standard 8-1/2 x 11 paper.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Zebra 2844 won't print anything.
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
Jan 26, 2009 | Zebra LP 2844 Thermal Printer
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Zebra lp 2844 thermal printer
It sounds like it needs to be re gapped. Try this:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Nov 30, 2007 | Zebra LP 2844 Thermal Printer
Lexmark X75 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
