Master
- Posted on Feb 26, 2011
Re: WATER DRAINING FROM FREEZER ONTO TOP SHELF OF...
This sounds like a defrost problem or a pluged drain line or both . in the back of freezer if you can see ice build up its a defrost problem . // i would replace the defrost terminator and deice the cold coil and see what happens . in most cases this will cure the problem mm feed back pls ..
