Computers & Internet Logo
A
Anonymous Posted on Feb 26, 2011
I have a Droid X. I am using the memo pad for the first time. I tried taking to the pad. My words appeared as the title of the memo, but I could not get my words to continue onto the body of the memo pad. How can I do this?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Feb 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
3025
Points
47
Make sure your cursor is on the the memo pad to where you can type it in the main body of your memo
How do I do a factory reset when it only has reboot or recovery setting on the asus
You can do a factory reset via the settings menu. Look for a 'Backup and Reset' entry.
tip
How To Reset Your Motorola Droid
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Press "Control+Alt+Delete" on your Droid.</li> <li>The phone will reboot.<br /></li></ol><span style="font-weight: bold;">Hard Reset</span><br />This will clear all of the data off of the device.<br /> <ol> <li>Turn the Droid off. If it won't turn off, remove and reinstall the battery.</li> <li>Open the keyboard and press the <b>X</b> key while pressing and holding <b>Power</b>.</li> <li>The device will power on. Continue holding down the buttons until a yellow triangle "<span style="font-weight: bold;">Warning Sign</span>" appears on the screen.</li> <li>Once the yellow warning sign appears, press the physical "<span style="font-weight: bold;">Volume UP</span>" and "<span style="font-weight: bold;">Camera</span>" buttons simultaneously to get to the menu. This may take several attempts before success.</li> <li>Use the direction pad to the right of the keyboard to select the <b>Format</b><span style="font-weight: bold;"> </span>option, or the <span style="font-weight: bold;">Wipe Data/Factory Reset </span>option.</li> <li>Scroll down to the "<span style="font-weight: bold;">Yes -- delete all user data</span>" and press the "<span style="font-weight: bold;">Center</span>" button on the D-Pad.<br /></li></ol>
Frozen asus memo pad
the memeory if full wont doload any apps,internal memery
2helpful
Trying to factory restore a asus memo pad
It not power on or it have a paswoard problem ? if is paswoard remove it with yoo pc and this program mobogenie instal it in you pc then conect and instal you memo pad in the pc then go to folders ask the paawoard archive edit it and ready clear all paswoard in to you memo pad vote please
Hi. I just sold my Droid A855. How do I remove all of my personal information, photos, etc. from the phone so that the Buyer cannot access any of it? Thank you!
hi,
hard reset your droid to delete all info..do this trick
1.power off, then.
2. power on holding the power button and the camera button together, a prompt will appear to release the camera button, release it .
3. D.O,S prompt appears
4. select system. recovery (volume down) you will get a exclamation mark with a triangle,
5.hold the menu button down an to the left for 30 sec.(square pad)( this may take several tries to activate the blue screen)
6. the touch screen is now active use the menu/scroll an highlight factory reset an press ok.
7. when done high light menu back option ON THE SCREEN an press ok.
step 4 is tricky don't give up.
1helpful
My droid wont unlock
DO A HARD RESET ON IT
*Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
*Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appears.
*Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
*Use the direction pad to the right of the keyboard to select the Format option
www.usedcellphoneshop.com
I list my item on ebay 24 hours ago and its still not on ebay. how can i solve this problem
first check if you successfully listed your item, you can check that if you already have the item in your active folder in your my ebay account under Sell. if not, you can try to list the item again.
you can also use the item number to search for your item, enter the item number in the search box. if your item will appear then your item is already and the auction already started. check the words in your title, make sure that you put in the same words that you have in the title of your item, if not your item will not appear. it really depends on what your item's title is, if you listed a car and the title is honda civic 2000 and you are searching for honda cars your item will not appear since the title of your item doesn't have the word car in it. make sure to put in the correct wordings when you are listing an item.
1helpful
3answers
How to play ps2 games on pc
there is the software called pcsx2 software which allow to play ps2 cds on pc
Grand Canyon Tech
Grand Canyon Tech
