Home | Zanussi | FC1200W Front Load Washer | Zanussi FC1200W
Zanussi FC1200W Front Load Washer
Problem for Zanussi FC1200W Front Load Washer
Zanussi FC1200W
By McYan on Jul 28, 2008
Washing machine does not spin and drain water.The machine is a Zanussi Electrolux Essential 1200. It washes but does not spin and drain. Could someone be of any assistance please?
Comments:
Aug 09, 2008
- Hi
Many thanks for your help.
I have done all what you have suggested.Also checked the back of the machine and found a white ball in the black pipe.I was not sure whether that is built in or an obstruction.
Can I remove it?
Thanks
Best Solution
posted on Jul 28, 2008
Very Helpful)
kjmac
Rank: Guru
Rating: 89%, 79 votes
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Comments:
Jul 31, 2008
- hi again
does the machine sound like its trying to pump out?
if it does there could be a blockage in the sump hose( black ribbed pipe running from the drum to the pump). when all the water is out of the machine, unplug it from the mains and tilt it back (you may need someone to hold it for you). looking underneath the machine the sump hose will be in direct view, just give it a squeeze and you should be able to tell if there is any obstruction as these pipes are usually very soft. if an obstruction is found then the sump hose will have to be removed and cleaned. however if no obstruction is present then there is a strong possibility that the pump will need replacing.
hope this helps
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi
Thanks for the response.I have tried the solution above on a couple of times but the problem isn't solved as yet.
If you/ any one else can suggest any other solution, that would be most grateful.
Popular Solutions for Zanussi FC1200W Front Load
Questions and Unsolved Problems for Zanussi FC1200W Front Load
Do you recommend Zanussi FC1200W Front Load Washer?
Answer
Answer
the lock symble is on how do i get it off
Answer
flashing lock symbol on front panel. machine wont operate
Answer
on my zannusi fc1200w, i just finished a wsah a nd the door wont open.The handle feels different to... (More)
Answer
I've cleaned out the filter and it's still leaking quite a lot. The water is coming from around the... (More)
Answer
Showing E90 machine will not run
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi FC1200W Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14051
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
