Question about Dometic Rooftop RV Air Conditioner
Lugging compressor on start-up
The compressor sounds (loud) and lugging while trying to start. In a few seconds, it kicks off and the fan continues to run. What is your opinion??
It may also be that your Start Capacitor has failed. The Start Capacitor provides a boost in power to the compressor when it kicks on, in order to overcome the high power demand on starting. Call Dometic with your unit's model number and they can help troubleshoot and/or supply parts.
Posted on Oct 13, 2008
Is the condenser coil clean?
Posted on Aug 05, 2008
Aveo 2004 lugging
i cleaned the egr valve on mine solved the problem
Jan 29, 2014 | 2004 Chevrolet Aveo
My DRB1901C is not freezing. It's sounds like its trying to kick over for a few seconds then fails.
If neither cooler or freezer is working it sounds like the compressor is locked up. When that happens it tries to start and will hold the start capacitor in until it overheats the safety contacts. It will overheat in about 3 seconds and then kick out. This happens sometimes if the door is opened right after the compressor has turned off because it is cold enough in the cooler/freezer. However if this continues time after time and the compressor does not start, you probably need a new compressor. You may consider a new refrigerator, since compressor changeouts are fairly expensive.
Sep 21, 2010 | Amana DRB1901C Bottom Freezer Refrigerator
I have a danby premiere model DPAC10071 & the dehumifier now wont fill external tank. every 2-3 minutes it makes a noise kind of like a fog horn way off in the distance(as if its trying to run again,...
it sounds like your compressor is failing to start ... that usually means a bad starting capacitor ... if thats the case it will hum loudly for a few seconds periodically .. thats the compressor trying to start but it cant if the capacitor is bad .. it will stop humming when it gets too hot .. a thermal breaker will turn off the power until it cools back down .. dont let this continue since it will eventually damage the unit ... replace the capacitor .. the capacitor is usually mounted on or near the compressor .. it often has two sections .. one for the fan motor and one for the compressor ... since they are both in one case you have to change them both ,...
Aug 15, 2010 | Danby Heating & Cooling
I turn it on (montana 5th wheel) and it sounds like it's tryin to kick in the compresor that is and the fan comes on and the compressor tries to kick in about every 30 seconds but cannot?? it's about 4...
The compressor is trying to start and cannot because it is broken inside and will need to be replaced. The compressor can be replaced by most anyone that is familiar with working on home central air conditioning units. I have replaced a few compressors for units like yours. Have a professional check it out. It could just be the start capacitor, but usually it is not.
Nov 15, 2009 | Dometic Rooftop RV Air Conditioner
When our refrigerator kicks on, after a minute or two it makes this loud whining, from soft to loud, that lasts about 2 to 3 seconds and does it continually till it kicks off. It's like, Waaaaah, waaaaah,...
This sounds like a compressor that is whining. Or something maybe wrong with the fan motor. You can stop the fan to see if its still there. If it is then its the compressor making the noise.
Sep 13, 2009 | Haier Refrigerators
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
237 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
