Question about Dometic RM2652 Refrigerator
Rm 2611 will not run on gas when going down the road
I have a 1994 RM 2611 Dometic ref. (2-way) in my slide in camper. Works well on 110ac or gas when camped however when going down the road will go out, check light comes on, will relight and stay on untill I move next time I stop same thing, have replaced the board with a Dinasor brand which was going to fix it NOT. any idea?
  • 51 Answers
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
Posted on Sep 07, 2008
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Recharging my dometic rm 2611
closed system replace cooling unit
Jan 17, 2014 | Dometic RM2620 Refrigerator
Hi I have a dometic rm 2453 and the freezer works fine on gas but the fridge doesn't work on gas. This has only just happened after a lot of dirt road travel. Thanks in advance for any help
It is all working on one system. It sounds like the thermistor inside the refrigerator is either in the wrong place or has failed. The white clip with the wire in it should be between the first and second fin. The higher you slide it up the colder it should get. If it is set right then go to the back of the refrigerator and remove the black cover from the circuit board. On the left of the circuit board you will see two harnesses plugged in. Unplug the lower harness (the one with two wires in it) and allow it to run for 24 hours. If the refrigerator cools down then you need to replace the thermistor.
Sep 10, 2013 | Dometic RM2452 Refrigerator
I have a dometic rm 2611, does not cool
If you can , run it on gas and see if it is OK- if so, you probly need an element.
If it wnot work on gas or electric you need a new sealed system
May 24, 2009 | Dometic RM2193 Compact Refrigerator With...
Rm 2611 ac problem
faulty selector switch, requires replacement. if you need to know how just send me an email and i would happy to assist you.
May 01, 2009 | Dometic RM2652 Refrigerator
Dometic RM 2662 Pilot light blows out in travell
weak pilot replace pilot generator assembly or check for blockage in line
Nov 30, 2017 | Dometic RM2620 Refrigerator
RM 2611 2-way ref. will not run on propane
replace the thermocouple cost is 12 dollars this is what holds the pilot lit thanks from gilles
Jan 30, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
378 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
