Question about KitchenAid K45SS Classic Stand Mixer
Switch The 10 speed switch sometimes will not remain in the "off" position. It springs ahead to 1 or 2. Does it need a new switch or lubrication and how do I take it apart to repair it?
  • ddawn98 Jan 26, 2009
    The 10 speed switch will not remain in the "off" position.
I solved this by calling Whirlpool corp. who gave me the name and number of the local authorized repair shop in a town near me.
Posted on Jul 29, 2008
I have a KitchenAid KSM90 Stand Mixer and it will only run on Speed 8. Any ideas?
Your description is very incomplete. Does it not start turning until the lever is at position 8 or does it run at high speed from the moment it starts at position 1?
If it's not starting until position 8 then the problem is probably mechanical and will require some parts to be replaced or adjusted.
If it starts on high speed at position 1 then it's likely you need to replace the phase board under the back cover at the top.
Whatever you decide to do check the carbon brushes first as worn out brushes can sometimes create funny speed problems.
Oct 18, 2017 | KitchenAid Food Mixers
Kitchenaid KSM150 Mixer's speed Off has become High and speeds 1-10 have become Off
The starting position for those top speed control plate screws with the lock nuts it 8 full turns in when you fit the plate. Correct adjustment begins in or out from that point. The bottom screw should have been left where it was to start with as that is for adjusting the start position so that when the lever closes the switch contacts to start the mixer the plate only starts moving when the lever moves to the second click. Try and get the bottom one roughly right and then work on the top ones. Turn it to the first click on the speed lever and then EVENLY adjust the 2 top screws to have the planetary turn 13 to 15 times per 15 seconds. Lock up the lock nuts and then check that the bottom screw is in the correct position with speed increasing a small amount as the lever slips into the second click.
Sep 15, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
My mixer wont stay turned off it springs back to number 1 speed so i have to turn off via plug socket
Shelly, usually this can be repaired without needing ANY parts! Its pretty simple but you do have to tear apart the mixer. Here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
99% of the time you are dealing with a loose screw. So take the mixer apart, once you have done that you will find the speed control lever with knob has a screw that holds it in place and in contact with the spring. That screw can work loose and if not all the way tightened will allow your mixer to pop back into speed one. Simply tighten the screw and see if the mixer will operate correctly.
If the speed lever is working through all 10 speeds correctly re-assemble the mixer. If it does not correct the problem you will want to buy the speed control lever kit.
This will include a new speed control lever with knob, the spring, link and a gearbox gasket.
KitchenAid Mixer Speed Control Lever Kit 4176230
The part number you will be looking for is 4176230, it is only about $7 plus shipping of $3.25.
-Colleen @ Mending Shed
May 14, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Why wont my classic kitchenaid mixer switch off
Good Morning,
There is a spring inside your mixer attached to the speed control switch and speed control arm, the spring can sometimes get caught on the slide bar that is just below it inside the mixer. The other reason is that the speed control switch plate in the rear of the machine (that the spring attaches to) vibrates the three speed adjustment screws out or in and the spring will pull the speed switch (control arm that you use to control mixing speed when using the mixer) back to the stir position after you try to turn the mixer off.
If it is a spring problem you will have to do a full tear down to get at the spring and either free it or replace it. If it is a problem with the adjustment screws on the speed plate, that can be handled at the rear of the machine and is twice as easy to get at but sometimes much more frustrating to adjust. There are "YouTube" videos on the internet that will walk you through the process of adjusting your speed control plate just Google "adjusting speed on kitchenaid mixer" I hope this helps. please let us know if it does and if you have other questions just post them here and we will "FixYa"
Sep 11, 2014 | KitchenAid K45SS Classic Stand Mixer
My K5A 300watt Kitchenaid mixer only goes one speed (as fast as possible) no matter what speed setting it is on. It also sometimes turns on by itself when it is plugged in but the switch is in the off...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 14, 2011 | KitchenAid Food Mixers
I have a Kitchen Aid k45ss that was dropped a few years ago. I works fine but the speed switch doesn't want to stay in the off position so we have to unplug it. I opened the unit and the switch...
When you said "the speed switch doesn't want to stay in the off position", you meant to
say "the speed switch in the OFF position does not turn OFF the mixer", or "the speed
switch physically cannot be moved to the OFF position"?
In any case, try to adjust the mixer speeds.
Obtain a copy of the K45SS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 21, 2011 | KitchenAid Food Mixers
The KSM150PS 325W mixer does nothing until speed control is moved up to position 8 or 10. Then when repositioned back down to say 6 it may run for a moment but then stops. It might just click on position...
You need to adjust the mixer speeds. Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Apr 22, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchenaid K5SSWH. It just recently started having a problem where it will only go up to certain speeds, then it won't speed up anymore. First it would go up to 6 speed, and if you put it past...
The brushes might need replacing. On each side, near the top of the body are 2 button that are unscrewed and removed. They have a spring and brush attached. There are fairly easy to replace. When I need new brushes, I order them from McNickels in Michigan. 1-800-562-4226
Sep 15, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Mixer won't shut off
Sounds as though the switch has shorted? Or the speed controller has failed ON. You could try a replacement if one can be had?
Feb 03, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Speed switch gone beserk
ANSWER
I have a K5-A, bought it for my S.O., she makes Krispy Cream doughnuts with it. The speed controller on a K5 has "originally" 2 return springs. They rust / break fall out the lower vents in the white cup that covers the rear of the machine. You can remove the cap with the removal of the lone screw at the top rear of the machine. Just gently work off the cap after the screw is removed. MAKE SURE THE MACHINE IS UNPLUGGED FIRST!!! There is a funny metal flange thing that is mounted with two screws at the top on springs. This is esentialy the speed controle. It is actuated by a rod conected to the outside switch that runs up the bottom of the motor drive. You'll note the simple but effective off / on switch there. When the springs rot the funny flange thing does not return to its flat resting position and we have no low speeds. The springs attatch to the holes on eather side of the flange and stretch down to a post type mount below the speed mechanism. If you use a good light you can see and mount any small spring to these mounting points and the switch returns to rest and you have all speeds, a single light spring will work.................There, You, Go..........Reassemble.
Apr 09, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K45SS Classic Stand Mixer Logo
183 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
