Question about Denon Audio Players & Recorders
After lightning strike, my denon ud-m5 displays "protected" when trying to play fm and doesn't work.
  • 57 Answers
Check the wire at the back of the FM Ant. If possible replaced it or relocate the FM wire.
Good luck
Posted on Jul 28, 2008
Cd stuck in Denon CD auto changer receiver. Displays ERR. How can I get out?
As there may be other factors at play that require a more detailed explanation, I would suggest that you seek a resolution through a discussion with a qualified technician. To do this, refer to your operating manual, which should provide a telephone number for technical contact assistance. You can also go up to the manufacturer's website and make contact for advice. www.denon.com/
Mar 05, 2015 | Denon Audio Players & Recorders
Instruction manual for a Denon UD-M50
This link should get you to a page where you can view/download the manual for this unit. Good Luck!
Oct 22, 2012 | Denon Ud-m5 Mini Hifi System
How to set time on denon ud-m3
press 'display' for 4 sec, then change hr with left arror, min with right arrow. easy
Mar 26, 2012 | Denon CDR-M30 CD Recorder
DENON UD-M30 CD Player is displaying the word PROTECT and will not function. Any ideas how to fix this problem? Many thanks.
HI:
Usually when a receiver goes into protect mode, there are several reasons, One is there is a bad speaker connected to the unit, this will cause the unit to to into protect mode, try disconnecting all speaker from the unit and turning it on if it does not go into protect then one of the speakers are bad. Another reason is the power output Amplifier IC is shorted inside the unit. Another reasons could be that speaker wires are touching each other and causing a short. Disconnect all unit connecting to the unit and try turning on, if it stays on and no protect then connect them including the speakers one at time until you determine which is causing the error. If it goes into protect with nothing but the unit on then the Output IC is bad and the unit needs servicing.
Mar 10, 2011 | Denon CDR-M30 CD Recorder
Denon ud-m30 Tuner problem I can tune am stations, but not fm. Receiver doesn't even receive signals from my nokia n97 transmitter 5 cm away on the known frequency. Is it possible that fm unit is out of...
I have just solved this problem with my system - it is caused by bad connections between the boards. There are multipin connectors that connect the main boards together via a small vertical board. Check that these are fully connected and you will probably solve the problem.
May 30, 2010 | Denon D-M30 CD Shelf System
Protect!!!
Have you unplugged it from wall since ?
and, do you know if maybe the speakers are blown?
Bad speakers will make it stay in "protect"
Try other speakers after the unplug-plug back in routine.
Try the Denon website for a manual
Jan 11, 2009 | Denon D-M50S CD Shelf System
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
Denon seperates
The most likely cause of this problem is the laser is becoming weak. You may be able to get a bit more service out of it by manually cleaning the laser with a cotten bud and some alcohol. However the only real solution is to replace the laser assembly.
It depends on how good at taking things apart and putting them back together you are, weather you should try this yourself. The laser assemblies often have the part number on the side of them, if not you will need to contact Denon who may tell you what it is if you are lucky.
Almost all laser assemblies come fully clibrated and all you need to do is remove the old one and replace it with a new one. You can get the parts from CPC in the UK unfortunately I don't know about other countries.
Regards, Andrew
Sep 14, 2008 | Audio Players & Recorders
Wont play CD's
saurus
please let us know if you get through to denon. I have been on hold as well for some time. Good to know that the problem is not unique but i hope there is an easy solution.
Dec 04, 2007 | Denon S-301
177 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
