Question about Kenmore 15218 Mechanical Sewing Machine
Machine sews only in reverse
How do I get my machine to sew forward? It will only sew in reverse though I have followed the instructions to:
hold down the reverse button to sew in reverse
release the reverse button to sew forward
The reverse button seems to be stuck.
  • 1 more comment
  • lpf43 Nov 30, 2008
    My machine sews only in reverse after working well a month ago.  When I push the reverse button, it sews forward.
  • Anonymous Mar 15, 2014
    I pressed the reverse button when sewing, and now I am not able to sew in forward
  • Anonymous Mar 16, 2014
    My Janome 642 sewing machine is stuck in reverse. The button that is pressed to reverse is not pushed down yet it still reverses. I have tried holding down the button again and releasing with no avail. Are there any parts that may be jammed and how do I fix this (if any)?
    Thank you for your time :-)
    New Friend:
  • 46 Answers
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Posted on Jul 29, 2008
  • Doris Olsen
    Doris Olsen Apr 13, 2014
    Add a thank you your info. helped me : )
    New Friend:
My kenmore 12 stitch was stuck in reverse. My friend used to work with a repair man, she said to open bottom some times thread is bound up, and may need oiled. My husband checked and found a bunch of lint and dust, he removed it and oiled it. My machine now works like new. Also sometimes the spring that operates reverse button can break or come loose. Good Luck!
Posted on Dec 06, 2012
Singer simple sewing machine will not move forward, but will sew reverse with holding the reverse lever down like it is supposed to do. I have been sewing for 50+ years. No simple answers please
Sorry--the only thing I can find is that possibly the auto reverse is turned on. Other than that, perhaps contact Singer directly or take it for service.
3221 SIMPLE Singer Sewing
Jul 08, 2016 | Singer Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
I just replaced the motor on this machine and when started it only sews in reverse. To get it to sew forward, I have to push reverse lever down.
The motor may have to be reversed. The reverse action of a sewing machine is the feed below the needle is reversed not the machine.
Dec 07, 2015 | Sewing Machines
How do I get a Service manual for an Industrial Sewing Machine
If the handwheel is really stiff and the machine is making awful noises, then your machine may need oiling. Don't know if this is the case with your industrial machine, but it may be something to consider.
Jun 12, 2014 | White Sewing Speedylock 1600 Mechanical...
My sewing machine now only sews in reverse
Maybe there's a problem with the reverse and forward button.
For sewing machine reviews
Sep 26, 2012 | Sewing Machines
I am having the same problem. Initially it did sew forward, but now only sews in reverse. The large grey lever on the right front of the machine should make it sew in reverse only as long as it is held down, but mine sews in reverse only. Hmmmm....think there are many people with this problem.
Jan 30, 2012 | Janome 2049LX Mechanical Sewing Machine
I can't find reverse on my necchi 536fb. I inhereted the machine it's pretty old but works great. Sewing would be much easier if i had a forward/reverse button. Thx
Hi! Sewing is so much easier with a forward/reverse button! :-) I have a Necchi 536 fb also. Here's a picture of mine: efebd8b.jpg
The knob on the lower right controls the stitch length and forward/reverse. Push the center part in to get reverse and release it to go forward again.
You really need a manual for your machine--my Miss Sophia came from a pawn shop so I ordered one from ( for $17.00.
I love my Necchi--you can read about her at if you like.
Happy Sewing!
Apr 22, 2010 | Necchi 3101 Mechanical Sewing Machine
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Kenmore 15218 Mechanical Sewing Machine Logo
2,250 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
