Question about Acer Aspire 5670 Notebook
What settings do I need to change to connect my Acer Aspire 5670 laptop to my LCD TV using the S-video connection?
    New Friend:
I have and acer aspire 5670 but i cant get it connect to my tv with the vga leads nothing comes on tv please help drving me mad
Posted on Jan 23, 2015
  • 520 Answers
Dont have to change any...connect s-video lead and press fn + the f key that has an icon of monitor on it (little square box)
for instance mine is f2 so I would press fn +f2 (not fn then f2 ,,fn and f2 together)
for most hp the f key is f4...
so you press togethher once and you have signal to tv ..press again you have signal on tv and pc press again and its back to pc only
Posted on Jan 24, 2009
My laptop is Acer Aspire 4920. When I connect to Samsung LCD TV nothing is coming. I connected properly. Can any body explain how to go about it
Make sure TV is set to connecting input port, like VGA or S-Video. "New Display" should appear on laptop.
Acer has more troubleshooting answers with helpful pictures.
http://acer.custhelp.com/app/answers/detail/a_id/5989/kw/monitor/related/1
Oct 05, 2012 | Acer Aspire One PC Notebook
Is it possible to connect my aspire 5670 laptop to a Sony Bravia TV (KLV32EX500) The TV just doesn't to recognise the laptop but has no problem with an HP laptop!
Welcome to Fixya. Yes you can use your Sony Bravia TV. After you connect the Laptop to the Tv press FN + F5 to toggle the display between the laptop and the TV.
Thanks for using Fixya.
Feb 21, 2011 | Acer Aspire 5670 Notebook
Broken vertical lines acer aspire 5670 laptop and
This is usually the actual screen driving transistors packing up, real common. replace the screen, if cheap enough, often though they are more than a new machine.
Feb 23, 2010 | Acer Aspire 5670 Notebook
Can someone help me connect my Acer Aspire 3680?
Your graphics card on that should push that resolution so I would probably lean toward the tv. Try changing the aspect resolution or (zoom button) on the remote to change the way the screen is delivered. As long as the resolution on the laptop is a widescreen resolution and the same for the television. Make sure in your tv settings, that the aspect is set at 16:9.
Jan 12, 2010 | Acer Aspire 3680 PC Notebook
How can i connect my acer 3000 laptop to lcd tv
you will need to connect through the s-video port, this should be a yellow colored port on your laptop (sometimes it is also black), and of cause you will need the s-video cable, you may need to buy one from you local electronic shop, once you got that done, then just change the av mode on your TV to s-video.
Sep 25, 2009 | Acer Aspire 3000 Notebook
How to connect my Acer Aspire 5670 outgoing to my TV? I have an SV cable and I believe there is an sv output plug for it. I'm not very technical.
You laptop can connect to any television or display device with S-video input through the S-video/TV-out (NTSC/PAL) port, located on the right side of the laptop (this is the round whitish port located between the two USB ports and the ventilation slots.
The computer has also an external display (VGA) port by which the laptop can be connected to a display device (e.g., external monitor, LCD projector).This is the port on the right side nearest the end of the computer.
Jul 27, 2009 | Acer Aspire 5670 Notebook
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
hi if you laptop has the s-video you can connect that to the tv an it would work
Jan 10, 2009 | Televison & Video
Acer aspire 4315 connect to TV problem
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
Sep 10, 2008 | Acer Aspire 5050-3242 Notebook
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 5670 Notebook Logo
324 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
