Question about Akai LCT2785TA 27 in. LCD Television
Wont come on
Red light just blinks
  • 3 more comments
  • brick9227 Sep 10, 2008
    • red lights blink
  • jwilliams401 Sep 14, 2008
    tv will not stay on - green light comes on when starting - blue screen with akai name appears- picture briefly flashes and the set turns off.
    by repeatedly turning the power to the set off i can sometimes get the set to stay on - very frustrating
  • npdaigle Oct 27, 2008
    is there any pictures or better description as to what needs to be purchased to fix this....maybe a parts list...??
  • DRAKEHEATING Oct 28, 2008
    2. IS TURNED ON.
  • Anonymous Nov 06, 2008
    when turning the set on Light turns green, and then red within 4 seconds.
    TV Set Neve comes on.
  • 5 Answers
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Posted on Aug 21, 2008
Thank You Tom, Your article about the capacitors for our Akai TV was so helpful and very cheap. So glad we don't have to add this TV to the landfill. This is a great site.                        dvcowgirl
Posted on Jan 11, 2009
Hello I replaced 4 capacitors that were blown,, now I have a green lightv and sound but no picture ,,, it will change channels with the remote e,,, everything operates but no pic thank you akai ----lct2721ad ser # rbmal co4251
Posted on Oct 29, 2008
  • Akai Master
  • 5,568 Answers
Hi Tom,
You must be retired (as am I) to have time for such detail - thanks.
A similar  problem to the one you found was instrumental in earning many thousands of bucks during the heyday of fax machines since they were failing all over and after spending enough time analyzing (my profession in earlier times) the problem I found it was common to all of them and made a separate business of repairing them in bulk for many companies around the US and Mexico. That lasted until several large companies discovered what I was doing to repair them and gradually out-advertised and undercut me. It lasted as long as I wanted it to; I had only started the one-man 'office equipment repair' out of boredom after retiring.
The primary failures though were in the feedback path that kept the supply ticking and the 10-47 uFd caps that were failing would fall to a few nanofarads before the supplies failed. The major caps in the front end hardly ever had to be replaced.   Along with using low ESR caps rated for higher frequencies, there is one other thing you can do to extend the life of the replaced caps; add some. After studying the reasons behind the failure of the caps used in switchers and adding the knowledge that the supplies would still operate nicely with only a fraction of the value originally used for feedback, I experimentally paralled rectangular ceramic caps (TRW, I think) of 0.47 uFd and rated at 50-63VDC and took a look at the result. I looked at the performance of the supplies with lower values but also, experimentally ran supplies with the chemical cap missing and found most would run well with only a .47 ceramic so I used them.
The fast-rising leading edge was handled almost entirely by the ceramics so the electrolytics were unburdened from handling frequencies they didn't like and result in their decay.   It cost a whole half-buck more but after leaving a salvaged supply under load for some months and finding the larger caps still like new, I warranteed my repairs forever and didn't receive any returns during the rest of the years I kept that semi-hobbyshop. They are still small enough to find a home for on any board I ever did.
Also, take a look at this link;
I can't find the original story about this problem but it seems the Chinese had stolen the formula for the dielectric fluid from a Japanese company and then stupidly modified it to save some yuan.
The dielectric was decaying on the shelf and was sold outside China to numerous cap manufacturers who produced millions of bad caps in the period of ~ 2003-2005 and there is no way to identify the turkeys so are still being used today and will fail early.
It was pleasant to find another (presumably) 'old guy' willing to take the time to give detail that might only interest a few.
Steve Allison
Posted on Oct 08, 2008
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Samsung Savyy wont trun on. it blinks red
please use other samsung battery same as your phone if not the issue is on the phone it self.
Dec 20, 2013 | Cell Phones
Sonytv bravia model# kdl55ex723 wont turn on red light blinking
The blinking red light should be blinking a certain number of blinks pausing briefly then repeating the blink sequence. If so whats the blink sequence?
Mar 24, 2013 | Sony BRAVIA Televison & Video
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
Jun 22, 2012 | Sony Televison & Video
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
Mar 20, 2012 | Televison & Video
Stereo wont turn on only red light is blinking
It sounds as if you are lacking accessory power to the unit. Insure that the red wire of the Pioneer unit is receiving 12 volts with the key in the accessory and on position.
May 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Akai LCT2785TA 27 in. LCD Television Logo
3,983 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
