Question about HP Color LaserJet 2600n Printer
Extra background color in my printing
When I print anything from my HP 2600 color printer, the entire background area of the paper is covered by a very light layer of what I can only describe as "overspray". It especially happens when I'm printing labels. If I do one label on a sheet, the remaining sheet is no good because the more you run it through the printer, the darker the "overspray" becomes. It's almost always a pink color.
  • Filman7 Sep 13, 2008
    I have the same exact problem. I too print labels. This is crazy, it shouldn't have a problem printing a few labels every now and then. It is a small office machine.
    Any suggestions on how to fix this?
  • 89 Answers
You really should not run labels through this machine unless they are full sheets. If you are running used pages the glue will build up on the tranfer belt and cause the hazing.
Posted on Aug 02, 2008
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
My problem is that when i print the black cartridge missing print area about 1 inch at right or may be at left side.this area comes white(mean no printing)i also change cartridge with new one but the...
you have something blocking the laser. if you remove the cartridge, look behind where it sits and you'll see a small line of glass going across. here you'll find its either covered in toner at the side your missing print or there is a ripped piece of paper. clean with a clean cloth or air duster
Oct 10, 2013 | HP Color LaserJet 2600n Printer
Can I get borderless printouts with HP CLJ 2600? I have had a look into the manual, but could not find an answer. Thanks in advance for a quick reply. /Tomas
It is never possible to print borderless on a laserprinter. It wil pollute your printer and causes problems. The only way is to print on a larger area and cut your printed paper afterwards.
Jul 03, 2011 | HP Color LaserJet 2600n Printer
HP color laserjet 2840 printer. no printing on the left side of the paper.
Hi
No print on the left side indicates that the toner powder on the left side is almost empty. Try to remove the toner cartridge and shake it well if the toner are new.
If still the same, you need to replace new toner cartridge to get better print out.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 19, 2011 | HP LaserJet 2840 Printer
HP 2600 is printing with a grey background. I have done several recalibrations and cleaned it but it does not fix the problem.
same as me, I got reduce this effect printing in normal paper as if i where printing transparency paper. The background is lighter now, but still appears.
The other thing I test, printing a blank page it was that with a glosy photo paper with the gloss side to the back i dont get any background. So i suspect it has to do with the tansfer belt ETB rollers.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
HP Color LaserJet CM1312nfi MFP printer leaves a 2 inch area unprinted using any programs. So basically it doesnt print the entire page.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are preventing printing
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for this type os trouble shooting
hope this helps and good luck
Apr 29, 2010 | HP Color LaserJet 2600n Printer
HP 2600 does not print onto photo paper
change the paper type in the printer properties and try.
Jan 09, 2010 | HP Color LaserJet 2600n Printer
Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Oct 17, 2009 | HP Color LaserJet 2600n Printer
Hp 2600
It migh be that there is not toner in your cartridges. Try to print test page from windows.
Sep 23, 2009 | HP Color LaserJet 2600n Printer
Yellow on all color printings
What photo program do you use? Is the yellow background on all Word doc's? You should check WORD go to the Format|Background make sure "no fill" is selected. You should also check your print properties in control panel and any special program DELL uses. Make sure there isn't some custom setting that is printing the yellow background. Let me know what happens. Good Luck, Tim
Feb 18, 2007 | Dell 962 Photo All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
418 people viewed this question
Seeker5211
Seeker5211
