Question about SanDisk Sansa e250 MP3 Player
HELP!!! again it's that when i open my mp3 now it says refresh database and it freezes and it stays on sayinh "refresh database". i have to wait till the battery dies so i can use it. but wen i try to plug it into my computer it still says "refresh database" and again i have to wait till the battery dies..ughh please help
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
"Refresh Database" freezing
Dude connect your mp3 player to your pc and then format it ... it will help alot...!
Thankyou. :)
Jan 08, 2010 | SanDisk Sansa e260 MP3 Player
My sansa e260 is displaying REFRESH DATABASE and the process continues so that no action can be performed.only a white light displays on the screen until the battery gets low.and a blue light displays on...
freezing at refresh database means there is a wrongly formatted or corrupt file tht you are attempting to put on your mp3 player. to fix this you simply delete whatever corrupted file it is. i, personally, had to go to settings on the mp3 player and at the bottom of the list is "format", i had to format which deletes all ur songs but fixes freezing problem. u only have to do this if you dont know what song is freezing it. if you do know, then you can go into your mp3 file folder under my computer( removable E:) and delete the song from there or you can delete it from your mp3 player via windows media player. to be ensure tht it never happens again you should just put each song on 1 at a time, disconnecting it after every 1, if it freezes again you know what song it is and you can simply delete it. i know this seems like it would take 4ever, but having to go back through and reformat every sinmgle time this happens would take even longer, so just stick with it. hope this helps
Dec 26, 2009 | SanDisk Sansa e260 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Need help to solve me problem
Hold down the power button and wait........
it will restart..
DO YOU HAVE a microdisk inside of it??? that could be causing the freezing...
Feb 18, 2008 | SanDisk Sansa e200 MP3 Player
"refresh database"
try formatting the hole mp4 *the musik partition only!!* or
try to use the recover mode and reinstall the hole mp4
more information u finds on google....
Jan 16, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e270 refresh database
Go under settings and change USB Mode to other choice. Then format. After formatting change back to original setting. I had same prob. Tech support told me to do this and it worked. Have had no problem since.
Jan 07, 2008 | SanDisk Sansa e260 MP3 Player
Frozen screen says: refresh database
tyr taking the battery out or try holding the power button and the play button at the sametime for 20 secs.
Oct 21, 2007 | SanDisk Sansa e260 MP3 Player
Database refresh on Iriver H10
I have done this. my iriver is almost full i have the 20gb, when the you do the database refresh, it just takes a really long time. mine takes about 2 hours to finish, once you see the clock on database refresh you cant do anything but wait till its finished.
Oct 18, 2007 | iRiver H10 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
