Ftp://ftp.dlink.com/Gateway/di614+/Manual/DI-614+_manual_06292005.zip Download the manual..
SOURCE: WEP Encryption
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
SOURCE: need to set up security for my DI 624 d link wireless router
Open a browser and type 192.168.0.1
Type in “admin” for the username and press "Enter".
Click "Home", click "wireless" (in the left panel)
Change your SSID to your liking. Do not use anything in the name that gives you away, like "LINKSYShome" or "Bob<House#>"...anything like "please try to hack me!" - you get me.
The DI 624 offers only WEP encryption in 64 and 128 bit, which is easy to crack (just google it!) and might give you a false sense of security. Nevertheless it is better than nothing and prevents someone accidental using your network, but you should choose a 128-bit-key and use random characters.
(128 bits divided by 8 bits per byte = 16 bytes. Minus 3 bytes used as "initialization vector" leaves you 13 bytes as key length.)
This key you can copy into a text file and copy it into the Network key settings, when you connect your computer. (Saves you from typo frustration...;-)
Don''t forget to save your changes!
Please let me know if this worked for you!
SOURCE: setting up firewall
Go to this link
The advanced category has all the configs to the router
So read it
Thanks
Good Luck
Please rate the answer if it helps u
SOURCE: I have a wireless d link router di-614 i never set
Here are the steps on how to set a password on your router.
Open your Web browser and type "http://192.168.0.1" into the URL address box.
Then press the Enter or Return key.
The logon pop-up screen will appear.
Type "admin" for the username and leave the password field blank.
Click OK
Once you have logged in, the Home screen will appear.
Click Run Wizard. You will see the following screen.
Next
Step 1 - Set up your new password. You have the option to establish a
password.
Click Next
Step 2 - "Choose your time zone", you will be prompted to select the
type of Internet connection for your router (see next page).
Click Next
The Setup Wizard (continued)
Select the type of Internet connection for your router.
Select one of these settings
If you are unsure of which setting to select, please contact your
Internet Service Provider.
Click Next
If you selected Dynamic IP Address, this screen will appear:
Click the "Clone MAC Address" button to automatically copy the MAC
address of the network adapter in your computer. You can also manually
type in the MAC address.
What is a MAC address? Each network adapter has a discrete Media Access
Control (MAC) address. Note that some computers and peripherals may
already include built-in network adapters.
Click Next
If your ISP requires a Static IP Address, and this option is selected,
then this screen will appear:
Do not use
Enter the IP address information originally provided to you by your
ISP. You will need to complete all the required fields.
the numbers displayed in these fields. They are only shown as an
example.
Click Next
If your ISP uses PPPoE (Point-toPoint Protocol over Ethernet), and this
option is selected, then this screen will appear:
Enter in the username and password provided to you by your ISP.
Click Next
Wireless Setup The default wireless settings are: SSID = default
Channel = 6 You can change these settings to match an existing wireless
network.
Click Next
Encryption The DI-614+ is capable of three levels of wireless
encryption - 64bit, 128-bit, and 256-bit. By default the encryption is
disabled. You can change the encryption settings for more secure
wireless communication.
Click Next
Your Setup is Complete!
Click Restart
Click Close
You will be returned to the Home tab.
Test Your Internet Connection
Click Exit Then relaunch your Web browser
