Question about Electrolux Microwave Ovens
I close the door of my microwave and the light stays on and the turn table rotates slowly. with a few slams it works again but there is obviously a fault.
  • Electrolux Master
  • 9,047 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a misaligned door.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Frigidaire Built-In Microwave
Microwave not working
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One giveaway is that you could gently lift up (and/or push down) on the door or handle to make it work.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Jan 10, 2010 | Sharp Microwave Ovens
Microwave oven, ge profile model #pvm1870 the light stays on when the door is closed. microwave makes a noise while the light stays on. slight pressure to the door turns the light off.
This is usually caused by either a bad door switch, a loose door switch mount, or bad door hinge alignment.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jul 17, 2008 | GE Microwave Ovens
Advantium 120 Keeps running
I've got this problem also.
The interior light on the oven died. We replaced it. Since replacing it the light stays on and the turn table turns.
Looking at the diagram, the "main relay" is what powers both. My guess is that it's stuck in the "on" position. Solution will be replace the relay.
Long term fix may be bigger relay.
Jan 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Microwave works with the door open
The top door switch is almost certainly defective or loose. Most likely the latter, and possibly due to a loose or broken mount. Chances are that only the fan and light are on, but it's not wise to take chances with microwave energy, whuch can cause burns and fire. One way to possibly test this theory is to pull up gently on the door and see if it stops doing it. But that's not a foolproof test. A broken or loose mount can be caused by inadequate plastic or improper assembly techniques during manufacturing, by slamming the door, or other physical damage. Bad door switches are usually caused by opening the door while it's cooking instead of hitting the STOP KEY first. I have a helpful text file on door switches with safety tips that will help you. You can find it by searching on Yahoo.com (not Google) for microwave safety.txt Good luck and be safe!
Nov 11, 2006 | GE JE1640WA/GA Microwave Oven
Turntable continues to rotate.
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files via a Yahoo search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide, but it's usually a door switch. If you still have a problem, please post again. Be safe!
Oct 29, 2006 | Panasonic NN-S264BF 1200 Watts Microwave...
Microwave Ovens Logo
135 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
