When you replaced the pressure switch, did you fully test the pressure switch hose?
Here's a similar posting that explains a potential issue and how to troubleshoot:
http://www.fixya.com/support/t8933273-general_electirc_washer_model
I highly recommend doing a diagnostic test because it's free and easy. Most of the time, the washer will self-diagnose. Check out that posting for instructions on how to do the tests.
Try to clean the discharge pump filter first (Instructions on page 13 of the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out these postings:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min http://www.fixya.com/support/t8933273-general_electirc_washer_model Do a diagnostic test -- Easy and free, and the machine will likely diagnose its own problem. Instructions in those postings.
Post back any code you find and we'll go from there.
