Question about Hoover Washing Machines
Trying to install new hoover 1600 aaa...all ok exept start button will not engage.don't have instruction manual...am i missing something obvious??
    Scholar:
  • 97 Answers
Hiya
has the machine been knocked that you know of? the reason i'm asking is that some of the new hoovers have button clusters which are made of plastic and are not very strong and i have seen them snap many times, could be the problem you have.
hope this helps.
saying that if its a brand new machine could you not just call out a hoover engineer as this should be covered under warranty.
Posted on Jul 28, 2008
Suddenly stopped steaming, tank filled steam light stays on, no steam but heats up? Problem solving in manual just states the obvious? Can you suggest anything else or will I have to contact Hoover
Perhaps Element not heating to full temperature to generate steam.
Temperature sensor may be faulty if element is ok.
1 Element or 2 ????
Sorry... No magic fix button
Open it up and start testing things.
a multimeter comes in handy here.
or
back to Hoover repair centre
Good Luck
Feb 03, 2016 | Hoover Vacuums
Battery on a 2005 Mustang went dead. Had a Jump to get the car started. Drove & speedometer & odometer worked fine. However, I had Triple AAA install a new battery & now they don't work. ...
Did AAA clean the battery cable connections when they installed your battery? Did you check the fuse for the insrument panel?
It could be just bad timing or a coincidense but I am more likely to think things are connected. If your gauges worked after jump starting your car, but not after AAA changed the battery, something changed or was left disconnected.
Jul 03, 2011 | 2005 Ford Mustang
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
Cannot open door and lock light stays on
It has a timer circuit that locks the door with a selenoid. It has a sprig that pulls the safety latch back off of the latch. Either it isn't turning the power off or the spring is broken or too dirty with soap and wont work right. Try pulling the power and see if that works. If not got to take front cover off and check it out.
Jun 01, 2010 | Hoover AAA140 Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Cannot get game to start
if you have tv cables an power cables you are ok if you have a game put it in make sure you connected the cables right
Mar 14, 2009 | Sony Time Crisis
Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Nov 23, 2008 | Hoover AAA160 Front Load Washer
Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Apr 11, 2008 | Washing Machines
Washing Machines Logo
144 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
