Question about Weber Genesis Silver B Grill
Loud and hot
Our 4-year-old grill suddenly makes a (comparatively) loud whooshing roar when you turn the gas on, and cooks extremely hot even on low settings. Swapped tanks, but no change. Any ideas?
    Novelist:
  • 116 Answers
The first thing to check is the orafice where the gas enters the burner. There should be a small hole in the tip where it enters the burner tubing. If this tip has come off or if the hole (manufacturing defect) has become enlarged. Then the gas flow will be too high.
Alternately the pressure regulator which attaches to your tank may have a damaged to stuck internal mechanism. This will cause too much gas to flow which can cause the issues that you describe. This can only be solved by replacing the regulator and hose assembly.
Posted on Jul 28, 2008
What is the life expectancy of a gas grill pressure regulator?
I've been in the propane business 28 years and have found regulators from the 1950's still in use today. Regulator manufacturers tell us they should be replaced after 25 years. It should typically outlast the grill itself, which often require new burners, cooking grids, etc. The hissing sound can just be the flow of gas thru the regulator. If you smell gas however, then you should replace it. If it is affecting the pressure to the burners and not getting hot enough to cook properly, then replace it as well.
Jun 06, 2015 | Weber Genesis Silver B Grill
Barbeque is making a loud high-pitch noise. Can't
The diaphragm inside the regulator is vibrating; that is what is making the noise you are hearing. You could go out and buy a new regulator, but first I want you to try something. What I want you to do the next time you light the grill is to not open the tank valve all the way...only open it about 1 1/2 turns and light the grill. If the noise goes away (which, most likely, it will) then the easiest way to correct it is just to not open the valve all the way. Normally, all one needs to do is open the valve halfway and the grill will get plenty enough gas to give you a really hot cooking area.
Or, you can go get a new regulator.
Dec 13, 2009 | Grilling
Loud "tire or wheel" roar on the highway
I certainly would take it back to the shop that performed the brake job and have them investigate. If it was not making the noise prior to the repair there is a good chance the noise is involved with the brakes. A possible loose brake pad, a sticking caliper(caliper pins may need to be lubed) or any number of things could be wrong.
Jul 04, 2009 | 2003 Ford Explorer
Tec Grill Sterling Model won't stay lit
The dealer is right. The ceramic burner is cracked. It will need to be replaced -- pretty pricey. I have the same problem on my Sterling III. This DOES happen too often. My opinion is that this IS a manufacturing defect. I have called the company about it (they are in South Carolina) and they try to blame the user -- that would be us. Very unfortunate company chooses to act this way. You hear about this problem again and again and again -- it's their problem but sadly, they are making it ours. Remember that when you go grill shopping next time -- I know I won't buy a Sterling grill again. Ever.
Feb 15, 2009 | Tec Patio II Grill
Loud roaring
Well i always liked LOUD CARS. But seriously maybe it is low on a resource. check the resources and if they are ok then maybe something has burnt out, in this case tak it to a mechanic and have it checked out by them to see what to do
Nov 18, 2008 | 1990 Chevrolet Lumina
Expensive TEC Grill Problem with Blowout After Ignition
HI nabber8391,
I have a TEC Pattio II. I have owned the grill for almost 10 years and TEC grills have a ten year warranty on many of the parts including the burners. The burners on my grill have a ceramic inserts. The pop and loud whooshing noises indicate the ceramic insert or the seal on the burner is "cracked". I have replaced both of the inserts and burners on my grill once about 5 years ago under warranty. I have one burner now that will not stay burning and I contacted TEC today regarding the problem, and I will replace the ceramic insert only under warranty. .
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE.
By the way, I paid $1400 for my TEC grill in 1999, but I believe the new TEC grills are better. I know I would not buy any other brand. One other thought, it is imperative that cleaning instructions are followed.
Jun 23, 2008 | Tec RadiantWave Grill
Sputtering grill
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom or sputtering.
May 01, 2008 | Tec RadiantWave Grill
Tec grill problem
If mositure gets into the ceramic burners, then yes it is time for new ones. Was your grill also converted over to accept the new gas? Or another thing it could be that spiders are clogging the burner orifice.. If you contact a local dealer on Tec gas grills or someone that can service gas grills. Might be able to help you.
Fireplacegirl
Apr 23, 2008 | Tec RadiantWave Grill
TEC grill
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. Confirm with TEC customer service that your grill has has this burner system and not the ceramic one. I assumed this burner system had eliminated the problem of the burners going out with a loud boom.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE. I WOULD NOT LET TEC OFF THE HOOK IF YOUR GRILL IS LESS THAN TEN YEARS OLD.
I noticed the skills of the customer service reps are lacking. You may need to talk with the manager. I love my grill and would not have any other brand or type. It is imperative to follow the cleaning instructions in you user manual.
May 14, 2007 | Tec RadiantWave Grill
Weber Genesis Silver B Grill Logo
222 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
