Question about Sony CDX-C7000X CD Player
Sony CDX-C70 CD Player Problem
BOTH 2a FUSES BURNED OUT ON TRANSFORMER BOARD, NOTHING SMELLS HOT
  • morpa Aug 03, 2008
    Mi equipo es una sony CDXc7000x tiene la falla de cuando prendo no hay sonido, adentrto el cd se nota que esta girando pero que no hay sonido. Hay momentos que tengo que sacar el cd y volver a prender y funciona, y el sonido queda en una sola intensidad no puedo aumentar ni disminuir el volumen. Sorry ayuda por favor.
    Problem Solver:
  • 4 Answers
Problem is in transformer on the primari or secondary or both side is short wireing. You should chang the transformer with the same type.
Robert
Posted on Sep 23, 2010
Hi, my problem is that each time I turn off the ignition I lose all my radio settings (i.e. the station pre-sets). My Sony is a CDX-L400X. I was wondering if there is an internal battery (like a button...
Hi, the problem is likely in the wiring or possibly a burned fuse. There is a separate wire to the radio that is always hot and keeps the station and clock settings while the key is off. If you tell me the car model and year, I may be able to tell you which wire and fuse to check. Was this working originally or has it never worked?
Aug 19, 2011 | Sony CDX-L400X CD Player
My Sony CDX-MP70 unit plays CDs and works on aux off my iPod but when I try to listen to am or fm it's nothing but static if I scan for a station it will just search forever, I took it apart but it all...
Check for a loose antenna connection, at the unit and where your antenna is attached to your car. Also, check fuses, some cars have 'powered amplified' antennas.
If those dont work, try resetting the unit. On most units there is a small pinhole behind the faceplate(not on the faceplate). Could also be the internal tuner has gone out...
Hope this helps
Aug 24, 2010 | Sony CDX-MP70 CD Player
Ampers for Sony CDX-S2210S CD
If the in-line fuse from the car installation is still attached, check the fuse rating; it will state a figure that is in excess of the demand of the stereo. In other words, if the fuse has 10A on it, it was chosen to fail at currents higher than that. If this unit is only a CD player (no amplifier built-in), it will not likely draw in excess of 2 amperes and probably not over 1 ampere.
If you have no documentation, you can download what you need here:
Sony manuals for your unit
Nov 15, 2009 | Sony CDX-S2210 CD Player
CDX-GT310 won't take a cd.
If the motor runing full speed , but nothing happens you got a broken or slip belt.
Can be tricky to replace lots of dissasembley
Jul 05, 2009 | Sony CDX-GT310 CD Player
My sony cdx 4000r is not picking up radio signals
sony cdx4000r not working correctly plays cd s inconsistently radio not playing ariel in place
Feb 19, 2009 | Sony CDX-4000X CD Player
Can my sony cdx 4000r play CDRW disks
according to sony , yes , you can play cd-r's , however they must be finalized when you burn them . your radio cannot play cd-rw's .
J5
Jan 19, 2009 | Sony CDX-4000X CD Player
Cant play New MP3 CDs on CDX-FM687
have you tried using another computer to burn them as some of the latest updates will give u this problem if not there are probably some compatability issues
May 23, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Eror insert cd
is this an burned cd or store bought?
lazer may need to be cleaned or is bad.
Mar 03, 2008 | Sony CDX-F5700 CD Player
Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Jan 08, 2008 | Sony CDX-S2010 CD Player
Sony CDX-C7000X CD Player Logo
71 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
