Question about HP DeskJet 6122 InkJet Printer
Rubber cable that pulls printer cartridges across page has snapped
Can it be replaced?
Bought a new printer.
Posted on Jul 29, 2008
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
I cannot get my printer to print in black. I have restarted, checked the power cables, replaced the ink catridge and still it won't work. It happened suddenly from one print job to the next
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Oct 04, 2011 | Office Equipment & Supplies
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Despite inserting new black cartridge (Brother LC57 BK), print is faint and on spreadsheets is blurred and has horizontal lines across pictures.
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem: - Replace the ink cartridge - Check the flexible cabling for continuity and for short circuits between adjacent conductors - Exchange the control board for a good one - Finally check the power supply
Good Luck
Mar 09, 2011 | Brother MFC 210C All-In-One InkJet Printer
Black stripe across copy
The orange roller is probably contaminated from toner that is sticking partly to the photodrum in the cartridge. That roller is likely made of silicone rubber (heatproof) that presses the paper against the fuser roller to 'fix' the toner to the sheet.
I suggest replacing the cartridge and cleaning whatever is accessible before you put the new cartridge in.
May 04, 2009 | Minolta Office Equipment & Supplies
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
My printer is printing blank pages What is wrong?
1. Remove the cartridge or cartridges from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridges back into the printer.
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Disconnect the power cord from the back of the printer.
2. Press and hold the button on the printer panel.
3. Reconnect the power cord and keep holding the button on the printer panel until the printer starts to pull paper.
4. The printer should now print a test page. Please note that the test is continuous. To stop the test, disconnect the power cord.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Apr 16, 2009 | Lexmark Z617 InkJet Photo Printer
Put new ink cartridge and can't install
Replacing your cartridge:
  1. Make sure the printer is switched on.
  2. Pull the operator panel forward and open the cartridge access door. (Note: The cartridge carrier moves to the loading position, unless the printer is busy).
  3. Pull the old cartridge forward and then lift it out.
  4. If the cartridge is new, remove only the sticker or transparent tape on the bottom of the Cartridge.
  5. Insert the cartridges into the carrier and push back firmly until they snap securely into place.
  6. Close the cartridge access door and the operator panel.
  7. From the operator panel, press Options to select the cartridges that were changed.
  8. Press Start (Start/Yes), Options to select the cartridge type installed.
  9. Press Start (Start/Yes).
Sep 16, 2008 | Office Equipment & Supplies
Printout
The paper is pulled in with rubber traction wheels on a rotating rod toward the bottom of the paper loading area. If these rubber wheels get slick or hard, they won't pull. Buffing the rubber wheels lightly with fine sandpaper will restore the wheels to the rubbery texture they need to pull the paper. But be SURE to completely clean any abrasive dust out of the machine before use. More information on that printer available here: http://www.retrevo.com/search/fv/63aac4a52ebe6e8d638f91867c39f9be.pdf#page=1
Aug 02, 2007 | Epson LX-300+ II Matrix Printer
HP DeskJet 6122 InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
