Question about Sony KDF46E2000 46" Projection HDTV
Sony kdf-E2000 The tv will turn on and then shut off for 30 sec. and then back on for 1 min. and off. It finally shut off and the red lamp light came on. It has now went to just blinking green when turned on now. Any thoughts? I heard I should replace the bulb, but I have heard of other issues when you do that and spending $200 for something that may not work really sucks. Is it worth fixing or look for a new tv? email me at shakenbake25@hotmail.com thanks for any help
    Novelist:
  • 135 Answers
I've seen this exact problem before and it was the lamp. Take it out (if in doubt) and look for glass fragments in the reflector. Even if the glass capsule isn't shattered, the bulb can still be bad. This is the easiest failure to visually confirm. A lamp should last between 2 to 3 years depending on the amount of daily use the TV gets. Should a bulb last less than two years the lamp cooling fans may need cleaned. Homes with a dust problem, smokers, pets and open windows are more prone to dust accumulation inside the TV. If you take the lamp out and see dust bunnies inside the lamp housing, the set should be cleaned and fans checked for dust deposits. Every six months or sooner vacuum the rear cover panel and area behind the entertainment furniture.
Posted on Nov 11, 2008
How do i fix my tv
I had the exact same problem. Thought I could fix it by replacing the thermal fuse . . . no luck there. Problem continued. After tons ( I do mean tons) of research, I found the problem to be a temperature sensor. Makes total sense ! ! ! The tv is trying to come on, but the temperature sensor is bad, telling the tv that it is too hot to operate, so it turns itself off - only to try & come back on 30 secs or so later. Hard to fix unless you know your way around tv circuits. Took me bout 3 hrs total.
Nov 08, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Just replaced lamp/housing and now tv turns off after 2 minutes of being on. Green light flashes continually(about 30 sec.) then tv turns back on and the cycle continues. The tv is a sony bravia...
Strange situation, have you tried unplugging it for a few minutes and letting the TV cool. I have a older 2006 Sony SXRD rear projection and it takes forever to turn back on if you shut it off then turn it back on. Check this link and maybe its giving you a blinking code. Try counting the number of blinks. Hope this helps.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 17, 2011 | Sony KDF-50E3000 Television
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TURNS ON OK THEN SHUTS DOWN, GREEN LIGHT STAYS ON
Mine does the same thing try a new lamp I am with what I have read this is the best solution. I have had green screen two fans replaced and now this. The picture was great but with all the problems i would never but a sony product ever again for anyone out there you should tell them sony sucks and send them to this web site for clues. Good luck.
Dec 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
My sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Jan 18, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF46E2000 46" Projection HDTV Logo
727 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
